Results 1 to 10 of 18
Thread: Gasmaster Butane Double Burner BBQ
    Dec 2012
    Just saw this double butane cooker for 60 bux on catchoftheday and ordered one seeing how I missed out on that other one similar to this, bugga, forgot the name of da udder one
  2. The Following User Says Thank You to wolften For This Useful Post:
    krbrooking (16th March 2013)
    Expert Dominator's Avatar
    Oct 2011
    I just upgraded to a gas (LPG) double burner. $50 from BCF, but you do need to buy a gas bottle too, I already had a 2kg bottle. I found those butane ones chew through the canisters way too fast.
    Rays Outdoors now sell them for $34.95 but they don't come in a blow mould case (which is huge) normal price is $50 rrp. BCF will have the same thing.
    I have the COTD one for about 18 months and its great but Rays have it all sorted now. The Blowmould case is massive!
    174 Post(s)
    I know that plenty of folks have used those butane stoves for ages without problem.......... But........ During our travels around Oz I heard of several first hand instances where folks had been using them & they blew up, luckily with only minor injuries, singed hair & the like. One person had their vehicle saved by a quick thinking neighbours with a fire extinguisher. The main problem is that folk tend to put to large pots or frypans onto them, which partially sit over the top of the canister compartment.
    However I removed the one I had fitted to an external drop down door on the side of our bus after the seal between the canister & the stove became leaky. First I knew was when I lit the stove the flames weren't where they were supposed to be. I reckon I was pretty lucky it wasn't worse.
    I had a heap of (brand name) canisters left over, & more recently bought a blowtorch attachment for them to solder up some Andersen plugs. New canister worked just fine for the first few I did, but then started leaking. I could see the vapour escaping. If I hadn't been on the ball it could have been pretty nasty.
    As a result I've now given up on any appliances which use those canisters, I just don't trust them any more. When using yours please don't get complacent with them. Check EVERY time you use them to ensure you have no leaks.
    Cuppa
  8. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    NP99 (16th March 2013), Stropp (16th March 2013), TPC (16th March 2013)
  9. #6
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Cuppa
    Good advice mate, plus I'm sure all those canasters are coming out of the same factory in South Korea.
  10. #7
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    I have the original U-Bute twin burner with hot plate and have never had an issue, also don't put over-size pots etc on it either. The blow mold case is very large and does take up quite a bit of room but still worth using it
    www.swat4x4.com
  11. #8
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Cuppa
    So are you saying that the hot gas is then forced over the canister ,and heats it up till it explodes ?
  12. #9
    Dec 2012
    ...some good info there.
    'Spose one should always check and tighten the canister before use.
  13. #10
    174 Post(s)
    Quote Originally Posted by 04OFF View Post
    Yup, if oversize pots & pans are used, which although obvious when mentioned, is something that is not uncommonly done.
