Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
Thread: Three dogs roof rack
    Yeah I know where's the pics?,
    Haven't been that flash lately but at least now I have the steel.
    size wise it'll be 1550 wide and 2000 long approx. This size will leave no off cuts.
    Another good part is I can lift it on and off at will. say I need to Zinc coat it
    just drive there and un load. The rear corners I'll 45. I'll cut it all up in the morning
    and tack it together, not a high priority job, just a job I want done.
  2. #12
    Nearly finished but having trouble transfering pics, roller has been tacked on in situ.
    All eyenuts welded on down each side for tie off points, a few more smaller cross members.
    Need to tack mesh floor on as well, the sides are being laser cut and should look trick.
    , Pic wth clamp not 45ed for a reason Size is 1800 x 1350 mm.
    Plus brackets for LED light bar and awning need to be welded yet as well,
    Way too hot doing this ATM
  3. #13
    Patrol God Stropp's Avatar
    34 Post(s)
    coming together well mate.
  4. The Following User Says Thank You to Stropp For This Useful Post:
    threedogs (12th March 2013)
  5. #14
    Re: Three dogs roof rack
    Looking good mate
    Owner of
    Westy's Accessories
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
  7. #15
    Yeah coming along nicely, just welding in 37 degrees outside that I dont like, lol Kallen Check those clamps from "ozmestore" on Ebay
    No need to Square roof rack , was 1 mm out as is corner to corner , happy with that. Roller off set on purpose, ticked off Laser cutter hasnt finished the sides yet.
    Should all be ready for powder coating by end of the week.
    Beats paying $1100 for a roof rack, main expense is the roof bars
  8. #16
    brisbane
    Looking good mate looking forward to seeing the sides.how much we're the clamps? They look spot on for welding.
  9. #17
    Dec 2012
    Quote Originally Posted by megatexture View Post
    X2 on the clamps, do you have a link as well? They would be so damn helpful and convenient!
  10. #18
    Yea there a top little invention. Just eBay 90 corner clamp.. mainly used in wood working but sweet for welding.. the better ones aint so cheap..
    Quick q, would you save more weight by making your own mounts over full width rino bars?
    Owner of
    Westy's Accessories
    Not sure I'd save weight as Rhino racks are ABS and alloy, so very light ATM.
    Clamps are made from cast iron and clamp material up to 50mm, no idea how to put
    up a link but ebay shop was ozmestore in S.A,. search of similar items may see cheaper price
  12. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (13th March 2013)
  13. #20
    My bad, the shop with clamps is ozmestore
    another seller is salstoolshed
