17th February 2013, 10:11 PM
sub light staying on
can't get sub pump to work? sub tank light is staying on the dash got the sub light to flash randomly but not pump. transfer pump not working? after ideas.
17th February 2013 10:11 PM
18th February 2013, 12:45 AM
Try disconnecting the battery for about half an hour. Sometimes the computer gets latched.
Steve
2011 Patrol Safari 4.8 (Fitek)
18th February 2013, 08:01 AM
Hardcore
How full is your main tank. If its close to full it'll do that
Such is the rule of honour.
18th February 2013, 09:21 AM
it would randomly flash every now and then when we pressed it but we only got that to happen 3 times. tank wasn't full it was under a quarter. will try disconnecting the battery. checked all fuses.
18th February 2013, 10:00 AM
well disconnected the battery and low and behold the pump started working cheers guys.
18th February 2013, 06:51 PM
its nearly worth putting an isolator switch in patrols.... the amount of problems just disconnecting the battery can fix.... make it easier then actually disconnecting the battery
The Following User Says Thank You to kull3n For This Useful Post:
wildgu6 (19th February 2013)
19th February 2013, 05:59 PM
fixed that now fridge keeps blowing fuses need the weekend to suss it out seems like its got a exposed wire
