Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Tralier mod time I think....
    Been there done that to I'll PM Where I got my trailer stuff from not far off ring rd for you in Tulla
    Disregard the 4x4 in the background, they were the DARK YEARS best not revisited
    Thomastown, Melbourne
    6 Post(s)
    Was there the other day as the mob I use have moved and are still not set up........ I break trailers all the time and am on my third gardening trailer!!
  4. #13
    Build a tuffer trailer in 1/8 checker plate, that one in pic [Blue} used to carry a Bobcat
    PM sent
    Don't weld drawbar to tub like my pic, just underneath both sides, smear silicon instead
  5. #14
    Just worked out that the spring rate on the current slippers is 600KG. So going 750kg would be better...
  6. #15
    Quote Originally Posted by Westy's Accessories View Post
    Your sounding similar to my olds to.
    As above go a 750-1000kg spring rate, set to the height you want (dont forget to deduct the tyre increase), and add a couple of shocks. It makes so much difference its not funny...
    And the water tank.. great idea.. mine is forward of the axle and is 70ltrs.
    My only grip is the tow ball weight.. the axle really needs to move forward 50mm...
    So imo, do the tank (rough mount), toolbox, spare tyre (if mounting up front) and draw bar, balance the trailer so you have ~30-50kg on the ball when tank is empty and you should be around the 70-80kg once tank is full.. once happy with axle position, weld it on...
    125x50x3mm shs is the pick for the draw bar if mounting box and tyre up front.
    And also go an electric brake system with override/ hand brake on the hitch... Imo a nice little feature to have. I wish I did...
    Also stick will be fine. 16tc low hydrogen would be the pick of the rods.
    Owner of
    Westy's Accessories
    Just going through these comments again and come to think of it, I have to really watch out I don't make the draw bar too long ad then I will be putting too much weight up front. Unfortunately I cant reposition the axles as the guards are already there. Maybe a water tank in the rear might be better to even things up a bit.
  7. #16
    43 Post(s)
    Re: Tralier mod time I think....
    Just going through these comments again and come to think of it, I have to really watch out I don't make the draw bar too long ad then I will be putting too much weight up front. Unfortunately I can reposition the axles as the guards are already there. Maybe a water tank in the rear might be better to even things up a bit.
    Yes that is a option.
    Owner of
    Westy's Accessories
    6 Post(s)
    Long draw bar for me always.... much better handling.
    I have owned many trailers including 3 gardening ones and swear by a long draw bar.
    Plus you get that room for tool box or something else.
  9. #18
    43 Post(s)
    Ok here are a couple of the axle/ shocks and tank setup.
    Owner of
    Westy's Accessories
    Think I'm gonna have to call in the big guns to help flip here over. BA! Keep your phone on mate
  11. #20
    330 Post(s)
    When I had my camper built by Tambo Campers I had an 80lt water tank placed behind the axle and a 60lt tank I. Front of the axle. Works a treat
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Bloodyaussie (13th February 2013)
