Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 136
Thread: How to make your own 4" stainless steel snorkel
  1. #101
    582 Post(s)
    Hi mate, this was a temporary thing for me as I knew I was adding turbo soon.
    I just welded on a 4" pipe to the square inlet of the pizza box. Filled in the circular gaps to the square with some steel strips, welded and siliconed any pin holes as I am a hopeless welder....lol
    Link here = http://www.nissanpatrol.com.au/forum...+box%26quot%3B
    It worked really well actually and 100% knowing it was all sealed. I don't like the original square mount Nissan made anyway.
    I was trying to find a 90 elbow 4" to 3"....Good score, wished I had of found that myself!!!!
    Jan 2013
    this is awesome mate . now i just need to pick up my sacks and start cutting holes ..
  4. #103
    582 Post(s)
    Quote Originally Posted by NZY60PATROL View Post
    Not hard to do mate, get your hands on a nibbler and you cannot go wrong with the cutting.
  5. #104
    Jan 2013
    was thinking of just using the multi tool as i already have one and then just cleaning it up with a file after .
  6. #105
    Jul 2012
    Hey Ab, finally sourced all the parts and did my own snorkel, hard a few issues at the beginning in regards to the nutserts as I had never used them before. I have a few recommendations, If you use the one of the self made tools and use the washer method which I recommend make sure the washers are tight on the bolt as I found the loose ones made the rivets bend side ways as the pressure increased and also try them on a sheet if you've never used them before, before you drill holes in the side of your car and they're too big. I used M10 size and found if I used a 12mm hole which I belled out with the drill bit till the rivnut fit tight worked best and bites really easily. All in all a good learning curve, to cut the hole I used a pair of tin snips and drilled heaps for holes and it worked sweet as. really clean job. heres a few pics of my attempt. I had a 4" - 3" reducer at the inlet and found an extendable air hose of the net, both cost about $ 20 each. made the brackets like Ab and yea just give it a go. Heaps o fun and frustration but ultimately a good experience.
  7. The Following User Says Thank You to eliurquhart For This Useful Post:
    AB (24th February 2013)
  8. #106
    Nov 2012
    Is there any legal implications with cutting the inner guard? I always though you couldn't cut it, looks very good and something i hope to do in the future, providing it doesn't cause any problems with insurance etc.
  9. #107
    Jul 2012
    If you take off the pre filter there is already a hole there that is 3" diameter, so no need to worry about that, im pretty sure that that is the original application for it.
  10. #108
    Jul 2012
    cheers for all the good advice Ab, finally got it on check out the pics I posted below
  11. #109
    582 Post(s)
    Awesome mate looks good, yeah good point about the nutserts and tooling.....Job well done mate!!!
  12. #110
    Mar 2013
    Melbourne vic
    verydetailed mate cheers going to use this to fix up my snorkels short comings
