29th January 2013, 11:28 PM
#11
lachiek
Mate thanks for this really useful post. I have the same truck / same issue with relay #2. I'll give your relay solder a go.
Hopefully you've found the glow control unit by now but if not it is on the passenger side footwell firewall. Worse position ever. Anyway hope these pics help. I'll be giving mine a clean with alcohol as part of the glow circuit tune-up.
I'll look there for the control unit, thanks. At least now I know what I am looking for.
My soldering job did not fix the relay. In the end I wired up a manual switch. I wrote about that here:
http://www.nissanpatrol.com.au/forum...414#post289414
Good Luck!
29th January 2013 11:28 PM
30th January 2013, 07:57 AM
#12
No worries, let us know how you go with it.
I'm gonna try the relay solder anyway and after that it could be a solution like the manual switch or this ... http://www.ebay.com.au/itm/121033317...84.m1423.l2649
I messaged the guy from ebay - says its an easy install and looks like it should work (the glow plugs are just the TD42 non ceramic 12 volt units). I want to understand the existing circuit better first then I might give it a go.
Cheers, Lachie
GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
