Results 1 to 10 of 14
Thread: v8 conversion kit
    Expert tassie wombat's Avatar
    orielton,tasmania
    v8 conversion kit
    Item for sale: marks adapter kit
    Price:1300
    Condition:new
    Details:
    Locationrielton,tas
    Contact:0409856853 or pm
    Comments:ive got a marks adapter kit to fit chev engine into a gq/gu patrol,
    come with-
    adapter housing kit
    marks rebuildable engine mounts and weld on chassis mounts,
    yella terra 11" flywheel,
    every thing is brand new,never fitted except the flywheel(was machined about 12 months ago)
    Nov 2011
    sorry stupid quest but is there a big difference between the chev and holden blocks?
    orielton,tasmania
    If the Holden block is chev bolt pattern ie was running a turbo 400 transmission then it should bolt up,but the engine mounts would be different.
    Jan 2013
    Pretty sure most holden motors weren't turbo pattern. Something in the memory banks thinks that. But i could be wrong
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Trimatics and Aussie 4 speed blocks had one bolt pattern, blocks used on turbo 350/400/700 engines were 'Chev' pattern.
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  7. The Following User Says Thank You to BearGUST For This Useful Post:
    tassie wombat (22nd January 2013)
    orielton,tasmania
    would also swap a set of 16 x 8 procomp rock crawler rims with cash adjustment if anyone was interested??
    orielton,tasmania
    anyone???????
  10. #8
    43 Post(s)
    Re: v8 conversion kit
    Pics always help..
    Owner of
    Westy's Accessories
    orielton,tasmania
    heres some pics off the marks web site,the only differance is the engine mounts i have dont have the extra annodised (adapter?) plate.
  12. The Following User Says Thank You to tassie wombat For This Useful Post:
    BigRAWesty (5th February 2013)
  13. #10
    Jan 2013
    What motor were you planning to use?
    Also I'm not up to scratch on holden/chev engines, would this be for an LS1?
