17th January 2011, 07:10 PM
DIESEL FUEL + 2T OIL = Superb performance?
HI can you enlighten me on this if this is true, saw some discussion of this but there was never a consensus... please want to know more about this
17th January 2011 07:10 PM
17th January 2011, 07:17 PM
SUCH IS LIFE
People use the 2T for lubrication as new diesel has a low lubricant in it. Extends life of component and some reports are gives better performance and fuel economy. Works well for some but not others...mixed reports
________________________
______ 2017 D-Max _______
18th January 2011, 08:53 PM
hi nisspat,
In your opinion would you use it.......
18th January 2011, 09:00 PM
SUCH IS LIFE
raneydelrey
hi nisspat,
Look, I have tried it and noticed no difference in my CRD so I probably would not use it.
There are people out there that swear by it(especially the 4.2 guys), so try it for a couple of tanks and see how you go.
Good luck
18th January 2011, 09:28 PM
Have been using Active 2T for some time in my TD42 an it does seem to make the engine run a little smoother an quieter.
90 maverick LWB 2" lift,General Grabber a/t
92 Coil Cab 3" lift, kl71 33"s n/a td42
The Following User Says Thank You to red92gq For This Useful Post:
1tuffgq (18th February 2011)
22nd January 2011, 10:09 PM
HI nisspat and red92gq
seems that it will work on a 4.2 engine but what about the zd30?
23rd January 2011, 08:09 AM
NissPat
NissPat - please, explain what is this 2T all about. Do we have this in PL?
23rd January 2011, 08:20 AM
2T is the type of 2 stroke oil you mix with regular unleaded petrol for use in chain saws etc. It is a mineral based oil, do not use synthetic based 2 stroke oils as they do not mix properly with diesel.
Tony
The Following User Says Thank You to YNOT For This Useful Post:
starck (23rd January 2011)
23rd January 2011, 08:22 AM
raneydelrey
Check post #10 in this thread; http://www.nissanpatrol.com.au/forum...0-Engine-quiet
Tony
23rd January 2011, 08:54 AM
Yes, sure. My old motobike used to fur on it.
So, what are proportions mixing diesel with 2T? I own Y60 with TD42T - so should be satisfied? Are there any problems later with hygiene of fuel system. Maybe doses of this oil makes pump or injectors rotten?
Sorry if this was already mentioned - then help me out with some link
