24th December 2012, 01:05 AM
Steering lock help
just pulled the girl into the carport for a check up and the steering lock is jammed,
supposed to be going away with it tomorrow
if anyone can tell me how to remove it would be appreciated, im about to call RAC but there not usually any good
'92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
Lukey 2.5" Performance Exhaust with Extractors, snorkel
Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
24th December 2012 01:05 AM
24th December 2012, 01:09 AM
BIG & BALD
Oh no, doesn't sound good. I hope someone can help tonight.
24th December 2012, 01:11 AM
Is the key in or out of the ignition?
Have you tried your second key?
24th December 2012, 01:45 AM
I would try lubing the barrel first.
This is how you remove the steering lock.
First remove the shrouds from around the steering column.
If you have a look at the back of the ignition barrel you will see that it clamps over the steering shaft.
On the top half of this you will see the remains of the heads of the security shear off bolts.
You will need to undo these bolts. I use to use a centre punch and hammer to do this.
With the centre punch start off by hitting it straight down on the head of the shear off bolt to make a hole on the outside edge. Then angle the punch down and tap the bolt in an anticlockwise direction.
The bolt should start to unscrew. I have also used an old flat blade screw driver to do this. Once you have removed the bolts the ignition barrel and lock will come off.
Then from memory it is two little grub screws that holds the electrical part of the switch onto the barrel, undo these screws and separate, then you can use a small flat blade screw drive to start the vehicle.
24th December 2012, 02:33 PM
You can drill the spring and ball out then it will have no more locking mechanism
27th December 2012, 12:15 AM
didnt have second key. got RAC lock smith out next morning. new key from some key code and all good.
merry christmas all
Sent from my GT-I9305T using Tapatalk 2
