Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 4 inch lift problem. Help asap!
    Can you get a pic of that? I think they are on wrong. The come with aluminium bushes to suit the chassis mount and I think they have them on backwards mate. That will make them like a radius arm spacer and that is how your springs present
    Yeah there is a boss there where the mushroom style bushes would normally sit in that would prob give you a gap of about 10mm or so.
  4. #23
    Im with mudrunner the drop boxes dont look to be on right. Do the cover the hole in the bottom of the chassis rail that you can normally see the radius arm nut in?
  5. #24
    What do u mean. All i know is they dont sit flush on the chassis rail where the radius arm use to bolt to.
  6. #25
    it sits against this ring here which sticks out a touch of the chassis. from what i can see also the cut is only 60mm deep but it should be 65 deep would this make any difference. It still doesnt touch the chassis except for that circle part.
  7. #26
    43 Post(s)
    Did you have this issue before fitting drop boxes?
    Did you use the same bushes?
    If you didn't fit it I'd be taking it back and let them deal with it..
    Owner of
    Westy's Accessories
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by BLKWDW View Post
    I still have that
    Are the lock nuts still straight, one of my lock nuts got bent somewhere along the line and it caused my tyre 2 scrub on my radius arm at full lock
    And x2 with Kallen, if a shop done your suspension lift install its there problem 2 sort it out, not yours
  9. #28
    Alright car is back down the suspension shop as of yesterday so fingers crossed theyll have it sorted by monday as i told him it needs to be done or i'll go elsewhere.
  10. #29
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Hope you haven't paid them or get money back for a poor job
    Such is the rule of honour.
  11. #30
    Legendary happygu's Avatar
    Your front diff is pushed too far forward.
    There are a couple of pics where it looks quite obvious. Once the drop boxes are installed correctly, it should elimnate this problem.
    Mic
