22nd October 2012, 09:28 AM
#21
i really must get me some good front points! the std one has worked thus far BUT when it goes it wil hurt
22nd October 2012 09:28 AM
22nd October 2012, 09:29 AM
#22
hey how much are the red ones up the top there?
22nd October 2012, 09:41 AM
#23
21st November 2012, 07:47 PM
#24
I learn every day on this forum. Found the hook under the seat when I bought Attila and wondered where it belonged! If the HT bolts are still in place it goes on tonight!
21st November 2012, 07:58 PM
#25
You are a bit far away, but don't use the factory flat point tow hook in anger it will snap and cause damage and god forbid injury, I could find out how much to post to Sth Africa. What year ,motor and bullbar have you got.
22nd November 2012, 12:03 AM
#26
Attila is a '99 4.5L with a nudgebar and integrated Warn winch. Model details I will dig around for (only had her for a month so still feeling my way around). Thanks for the offer to help; really appreciate it.
22nd November 2012, 06:18 AM
#27
Yours will have the larger radiator, not sure if you have two captive nuts under the chassis both sides up the front, if not. one bolted to the inside of chassis rail will keep you safe.
take it you're rhd over that way. would make no difference anyway .I'll go to PO today and get best price .
22nd November 2012, 05:15 PM
#28
Thanks for the guidance and help. Thsi forum has been amazing. Solved two other electrical problems this week on other threads; relatively simple problems that would otherwise cost me a packet using a dealer (few and far between here). Yes, we are also RHD and it is the one with the long radiator.
For what its worth, we bought Attila 2nd hand because we want to see how much we like the idea of upgrading our outdoor lifestyle (we previously had an Isuzu doublecab) before we go out and spent a packet on a new wagon. I plan to retire in about 5 years time and would like to tour Africa south of the equator (some of the most amazing mountains, deserts, swamps and jungles). In preparation we intend using Attila to learn about all aspects of 4x4 skills, safety and maintenance without the worry of damaging or wrecking a small fortune in the process. Once we are happy with our skills we can then upgrade to something newer.
30th November 2012, 09:44 AM
#29
Hy three dogs have sent a pm regarding some recovery points,
thanks
Mark
2007 ST 3L Turbo Diesel Manual Patrol - Stock as a rock ...
11th April 2013, 09:29 PM
#30
I always understood the front chassis hook and rear loop to be rated for recovery as it states that in the owners manual. I am a bit dubious using it, but have used it in the past. I will replace with proper once to have piece of mind though.
