Results 1 to 9 of 9
Thread: Gq front axle seal part number?
    As above..
    Chasing a part number if anyone has one.
    I have the dimensions
    65mm id x 88mm od x 9mm thick. double lip.
    Chasing a brand and part number so i can get one locally today.
    330 Post(s)
    Check ebay for item. GQ axle seal. Sorry on my iPhone now
    yeah not really what im chasing. Evilbay is a rip. local seal shop will be about $3.
    330 Post(s)
    Quote Originally Posted by davo94 View Post
    Yeah but it aint that hard mate. I am now on a computer and it took me 2 minutes to do what i recomended you do and got what you needed =======> The Part Number!
    See this Add mate!
    The Part Number is Here! - Searched "GQ Axle Seal" on Ebay - 5th item listed
    Thanks but again I was more chasing the part number of the seal manufacture rather than the genuine part.
    330 Post(s)
    I would have thought your local Seal place should be able to cross reference that for you? Give them a call and quote the seal number in that add and they should be able to check their supplier catalogues?
  8. #7
    Im wanting to order before removal.
  9. #8
    330 Post(s)
    Yeah no Probs but you have the size in your first post and you have the Part Number from Nissan your local bloke should not need anything else to find that seal for you mate in any brand he sells
    That is probably More Info than he needs??
  10. #9
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    x2 with Darren, you would only need the original Nissan part number and your local seal place will be able to cross reference it, if they can't do that I would not be buying a seal from them in the first place
