6th November 2012, 07:45 AM
Removing manifolds what else should I do?
Hey all, any advice appreciated here.
I'm removing exhaust and intake manifolds to replace my turbo but will also do a carbon gunk cleanup.
Is there anything else I should do while I have the manifolds off? Any tips for removing this stuff?
Cheers, LAchie
GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
6th November 2012 07:45 AM
6th November 2012, 07:58 AM
Gasket remover & / or a good narrow paint scraper.
Make sure you got all the necessary parts before you start.
Allow another 1/2 of the time, because it always takes longer. Start on Saturday morning or weekday. That way there is back-up time in case you need something else you forgot.
Ensure you block passages into combustion chamber so you don't unintentionally cause more problems.
Use an air compressor to dry / blow crap out.
Wear safety glasses.
Use a soft-blow hammer to tap a stuck flange loose.
Keep a couple parts trays near by to keep your bits together.
You could port-match manifold to block using bearing blue or similar.
We got some serious degreaser called corium. It's awesome, but clean away all residue before you re-install.
Loctite 515 / 510 flange sealant, 222 thread lock & 243 stud lock helps a great deal in sealing & keeping parts together.
Take it slow, do it once.
Use the correct torque for all bolts.
I did mine on my ZD30 & some bits were fiddly as, others ok.
Double-check connections before you crank her over.
Have fun, keep pics & enjoy
06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
The Following 3 Users Say Thank You to Lieney For This Useful Post:
boots (6th November 2012), lachiek (6th November 2012), MudRunnerTD (11th November 2012)
6th November 2012, 09:13 AM
Take a pic at each stage, so you can go backwards threw your folder and install everything how it came off..
Owner of
Westy's Accessories
6th November 2012, 06:02 PM
Thanks guys, all good advice. What about other engine areas that I'm going to expose with the manifolds off? I'm thinking I don't want to do this again for a while....
8th November 2012, 06:00 AM
If you have an intercooler, i'd flush that, or at least have a look at th einternals to see if there is any buildup.
11th November 2012, 06:48 AM
Yes while you have your manifolds off check all your hoses and clamps. I had a coolent leak, the only place i could see wet was the back of the head by looking from underneath along the top of the gearbox.
I thought was head gasket but was a small hole in one of the heater tucked up above the starter and under the intake manifold. By the time i got to that i was ready to take the head bolts out
'92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
Lukey 2.5" Performance Exhaust with Extractors, snorkel
Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
![](image.php?u=11821&type=sigpic&dateline=1354132168)
12th November 2012, 04:34 AM
Clutch master rebuild.
Service Starter mtr .
Replace all water and vac hoses.
Flush cooling system.
before you remove manifolds.
New thermostat.
Service alternator.
list is endless
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
The Following User Says Thank You to Robo For This Useful Post:
lachiek (12th November 2012)
12th November 2012, 05:20 AM
Robo
New thermostat.
Service alternator.
list is endless
How do you go about servicing starters and alternators?
Sent from my GT-I9100T using Tapatalk 2
The Following User Says Thank You to Rustyboner81 For This Useful Post:
12th November 2012, 07:36 PM
Robo
New thermostat.
Service alternator.
list is endless
Shit - right - just turned into more than a backyard job! haha thanks Robo.
13th November 2012, 09:15 AM
its all good, ive done most of that in the driveway
when you flush the cooling system be sure to back flush it first to help losen any crud up
check this out its not patrols but lots and lots of good info ericthecarguy.com
