Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: uhf antena security
    Expert stevogq's Avatar
    behind you
    uhf antena security
    ok early this morning i heard some noises outside my window so as i looked to see what it was i noticed 2 teens trying to pinch my uhf antena so quickly ran outside and gave them a hounding and a one and only warning before i send them to the hospital, now my question is what have you done to prevent the antena to be stolen eg: tacking a spotweld or something else.
    cheers big ears!
    Aug 2010
    adelaide
    loctite mate works a treat
    OH LEATHER IS NICE
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Yep, removable loctite is probably the best bet ... welding is good, but somewhat more permanent! lol
    Should have offered to help them take it off, and then whipped the bejeezers out of them once it was off!!
    I drilled mine and tapped a roll pin into hole.
    remember to if they get ticked off they may end up just snapping it for something to do.
    Get back to my Pitbull bull theory again,
    behind you
    you know i never thaught of loctite lol ill just put some on today,bigrig i got a scanner antena thats double in size so i can whipem with that hehe
    behind you
    pitty will work a treat but i cant understand why my goldfish wont look out for my car
    43 Post(s)
    Quote Originally Posted by stevogq View Post
    There a great intruder alarm.. But we can't speak bubbles... (the language of gold fish..)
    Owner of
    Westy's Accessories
    If anyone does try a tack weld (which i don't recommend as I regularly swap radiating elements to suit the terrain or replace broken ones from low flying tree strikes) totally disconnect the set so you don't let the smoke out of the RF stages.
    Unfortunately the scumbags normally either pinch or wreck whatever they want so sometimes the attempted prevention is more of a PIA to the user. Loctite is a good idea or a roll pin, or a small allen key or tamper resistant style screw drilled and tapped such as GME use on some antenna bases so people can't just unscrew them by hand.
  10. #9
    brisbane
    Locktight and I have my cord in copper plumbing pipe pop rivited to my bull bar as I've had some one pull the cord out of the base once before works a treat
  11. #10
    behind you
    ok ill drill and put a pin though it
