5th November 2012, 06:31 AM
vin plate
while working on my mk today was in engine bay i had a quick look for the vin plate but could not see it
where should the vin plate be located as i am in the uk my mot is up at end of month and if they cant locate the vin plate it may fail
maybee i am being thich but looked on the slm panel and bulkhead but no sigh of it
cheers
Lee
5th November 2012 06:31 AM
5th November 2012, 06:51 AM
It should be rivetted to your fire wall i front of thr driver RHS, its about 70mm by 60 mm with all you vechicle info on in,. will put pic later unless soneone beats me to it'mybe different in the YK?
wouldn't think so though,look just below window height just where bonnet seal is, in engine bay , lift bonnet top lhs. if cant find it get off the guiness. LOL
Should around 3 vin numbers, on your chassis rail behind the front wheels and on the firewall
Sent from my HTC Sensation XE with Beats Audio Z715a using Tapatalk 2
TD42 turbo GQ - ironman snorkel - 4 inch flexy coils - 6" shocks - 3" straight exhaust - pyro and boost gauges in A pillar- uhf - winch - sunraisers - Bluetooth - spotties - front lokka
6th November 2012, 07:35 AM
well had a look round the engine bay tonight and i cant see a vin plate
so that might be another problem to overcome can find a big sticker with engine codes on it but thats about it
cheers
Lee
6th November 2012, 09:04 AM
The chassis rail VIN is on the drivers side in front of the wheel
19th November 2012, 03:39 PM
The VIN plate is located on the firewall,right side looking from the front,if there are a couple of holes few inches apart,with nothin then its not there anymore
There is another plate locating behind the left headlight,looking from the front, located on the inner wheel arch,look down behind th headlight
The main plate for rego is one on the firewall,that has all the info for rego
20th November 2012, 11:01 AM
Well... On my 1980 MQ (W.Australia), the VIN is pop riveted to the inside fender, just behind the coolant overflow bottle. The MQ is one owner (me) so the VIN has always been in that spot.
cheers,
george.
2nd December 2012, 01:17 AM
#8
georges80
cheers,
george.
I too have found them there on mq/mk
Tim
