13th October 2012, 04:16 PM
Administrator
13th October 2012 04:16 PM
13th October 2012, 04:20 PM
Its not the rear main seal is it?
Or front main seal of gearbox??
Hello from Under Down Under!
13th October 2012, 04:23 PM
Administrator
taslucas
Not rear main seal....
13th October 2012, 04:28 PM
Well thats a good start
13th October 2012, 07:59 PM
Smart like tractor
are you able to drop that inspection plate at the bottom of the bell housing and have a look inside, you may need an inspection mirror to get a visual on you main shaft seal????
if you lived in qld a fair few of us would be around to help sort it as that is what us qlders do lol
96 GQ coil/Cab
08 G6eT
13th October 2012, 08:18 PM
Thats a big leak AB ,thats not seeping?
When did you change clutch last?
13th October 2012, 09:15 PM
Administrator
Ben-e-boy
Thanks for rubbing it in mate...lol
I'll suss that out tomorrow, cheers
Administrator
threedogs
Clutch was only done about 4 months ago mate.
13th October 2012, 09:21 PM
Looks like a rear main. What colour is the oil?
13th October 2012, 10:45 PM
From what I read here every one says change rear main at the same time you change clutch, you done a boo boo??
Also is your bellhousing tight, no shuddering on way home???
