Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 69
Thread: Which exhaust.. Beaudesert or Redback ?
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Honestly. What would make one of those two brands said to be the better? Say if they were both 3inch and mandrel bent? Nothing... Stainless steel? I see no point, but its up to what you like, you can't really see it anyhow. The only real factor I could think of is the Cat, whether it's guts are ceramic or metallic and maybe the muffler. Other than that your just paying for a brand name.
    But I have a 3inch Redback system I got for $900 and I fitted it myself. Much cheaper than whats advertised in Ebay...I went through all this rigmarole too and just went to my local zorst shop and he sorted me out good with the system I have now.
    Good luck.
    Totally agree with you mate - exhaust innovations did mine at Capalaba (Brian - top bloke) and just like you say, it's a bent pipe ... other than material used, price, and the cat (of you have one), it's still just a bent pipe ...
    Legendary Alitis007's Avatar
    15 Post(s)
    My 2 cents, redback mild steel mufflers corrode after 1 year on normal sedans that get driven daily on the road so i can only imagine what will happen wen you go off road. Best bet is to source stainless steel exhausts worth the extra $$ IMO.
  4. #13
    465 Post(s)
    Each to their own, but the standard exhaust is made from mild steel and mine old exhaust was 11 years old and there was no sign of corrosion...Corrosion in mufflers normaly happens when the car does a lot of stop/start traffic and doesn't get a real chance to blow out the condensation. So the moisture just sits there and does its thing. I found this years back (20plus years) when working in an exhaust shop.
  5. #14
    Expert Ronin's Avatar
    Brissy
    great feedback guys... for now I will go for the exhaust .. then a snorkel and then a chip and hope the missues is still with me...
    another question, being a new GU, I got the extra 3 years warranty as well from Nissan. Putting in the exhaust should not void it ?
    From the feedback, I am leaning towards the beaudesert exhaust...
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  6. #15
    15 Post(s)
    It probably will check with your dealer what the conditions of your warranty are.
  7. #16
    465 Post(s)
    Do you have a price for the two?
  8. #17
    Brissy
    not yet. I am kinda expecting that both will be about the same price range.
  9. #18
    Sorry I'm against the lot of you. unless already done I'd be fitting boost and EGT gauage so I can monitor any changes a new exhaust will make.
    Could be doing unseen harm without them , thats my 2cents worth. Then Chip and Zoorst at same time you'll notice a huge difference then
    Not much change from $3k for zoorst and chip
  10. #19
    22 Post(s)
    I have a beaudesert exhaust and mine sits quite high between the chassis rails I have never hit it bottoming out. I bought a beausesert exhaust based on that recommendation
    Benny
    96 GQ coil/Cab
    08 G6eT
  11. #20
    You'll find the Beaudesert ones are alluminized steel , high tech
