Results 1 to 6 of 6
Thread: Lpg fuel gauge mod using the dash cluster
    well anyone using the l.e.d lpg gauge will know how useless they are.
    Years ago when i had a petrol gq i wired mine up to the one in the cluster.
    It worked great and didn't jump all over the place just the same as it did on petrol.
    All you need is an lpg sender to suit your tank with these ranges.
    4.3-5.7 ohms full
    74.3-84.8 ohms empty or something close like this
    http://www.ebay.com.au/itm/Axiom-LPG...item4abb63a405
    Then just switch the signal input to the gauge when switching between gas and fuel .
  2. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
    patch697 (31st August 2012)
    This is what I need! LED LPG gauges suck!! Mine goes down a bar when I put my headlights on sometimes
    Tappa tappa
    Banned
    Quote Originally Posted by KRISTOFFA View Post
    Tappa tappa
    You can get a tunable gauge interface as well which will do the same thing, also not to expensive & not hard to install. Some even come with a button for the dash which allows to switch back to your other tank to check your fuel levels without switching back to that fuel... Very neat.
    Legendary timbar's Avatar
    Feb 2011
    perth
    tell me more my lpg gauge doesnt work and never has
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Anyone got more detail on how to replace the led gauge?
    Patrol Guru
    Apr 2011
    Melton
    You would need to run a relay -(this is how my ef is set up).
    Switch the gauge wire from the tanks with the pertol tank gaude wire -9 the manual shows t as y/b in the chassis wiring to the tanks.
    Use the LPG gas soniode control wire to actiave the relay (make & brake) - normally off - petrol
