Results 11 to 20 of 32
Thread: Fitting GU Recovery plates.
    Are these your Threedogs? My missus wont say where she bought them from but I saw pics of yours and they look the same...
    Legendary happygu's Avatar
    Mudski - Good Job - looks like an excellent fitout, and you can never be too sure with recovery points unless you know they are done right, and yours are done right.
    Mic
  4. #13
    Thanks for the detailed information on how to fit them too, as this may help someone else who might be tempted not to do them the right way.
  5. #14
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Mate,...... that's a neat job, well done
    Cheers, the ferret
  6. #15
    Thanks for the, thanks guys Just trying to put back into the community here what have given me so much.
  7. #16
    Hi Mudski look like copies, mine would have a yellow sticker on them.
    but apparently you're allowed to copy anything and get away with it.
    Good fit up too. First to have these fitted to a GU.
    Are they rated????
  8. #17
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Are they rated????
    That you can unless you spend the $$$ to patent your work and then even then you can someone can copy it make it bigger by 1mm then its know longer breaking the rules *L*
  9. #18
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    Quote Originally Posted by nipagu7 View Post
    probably a stupid question guys , but would it not be easier and perhaps even stronger to have recovery points on the bull bar . Or is there a reason ( possibely stronger ) that they are located where they are .
    I have that shape from TJM (your originals threedogs :-) ) that I fitted to my Mav/Q. They are fairly deep. Where I have mounted them in the Mav is on the bolts that hold the front bar on, and I think the recovery points are now the lowest point at the front.
    Putting them further back where mudski did would preserve the approach angle.
    Mudski, thanks for taking the time to prepare the report and clear photos. Nice work!
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  10. The Following User Says Thank You to Silver For This Useful Post:
    mudski (11th November 2012)
  11. #19
    I dunno threedogs. It had something on them as I can tell she's tried to clear any markings off them...Plus she did go out Coburg way a few weeks ago and there is a TJM out that way. Hmmmm. Anyhow, I'm stoked. I will soon know if they are not rated when I will need them.
  12. #20
    Ideally where the bullbar mounts to the chassis would be a good spot, but with different models, bullbars etc it was universally easier to try and come up with a one to fit all styles.
    I have 6 styles to suit the GQ/GU, just in case of a whacky bullbar, even have one that will bolt to the tie down point, but not sure how strong it is in the first place, if it was ok I'd only need one style
