Results 1 to 10 of 10
Thread: door trims hand made
    Advanced pjwooly's Avatar
    Gold Coast,Aust.
    Has anyone here made their own door trims for their GQ.
    I'm thinking of doing so but would like a few pointers and hear of any probs you may have had.
    Please include some pics if you could....
    Pj
    i would also like to know. mine are pretty sad and i have often thought of doing the same thing
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi mate,
    Have moved your thread into the DIY Section under: Questions related to DIY project.
    I will be interested in this thread as mine needs doing to.
    Is your windows Electric or Manual? I assume there would be more work involved if you have electric windows
    Todd
    Its pretty simple if you have the old door cards.
    I'd recommend using a decent 3 or 5 ply rather than MDF, the originals are made out of Masonite. Use the originals for a pattern and just trace around and basically copy cut everything. If you want to cover them then buy some vinyl and glue it on using vinyl adhesive from your local Bunnings
    All the fittings will screw straight to the new card, ie. window switches and arm rests etc.
    Alternatively 3mm Aluminium sheet but a little more difficult to work with and unless your going to leave it exposed and like the shiny look i would not bother.
  6. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Rirz (17th March 2016), rusty_nail (22nd August 2012)
    Gold Coast,Aust.
    Yeah thanks mudrunner thats what i was thinking too.I do have the old ones but they are a bit buckled.Remove them and maybe weight them down for a night mite help to flatten them for retracing.I have seen some done in checker plate and thort that looked pretty cool.
    What about the fixing to the door tho? Do you just screw them? Use the old clip things somehow? or what. With checker plate i think i would run a thin rubber strip around the edges,but for ply you may not need to.
    I gave up on the factory clips years ago in the GQ and went phillips head tek screws and i reckon it looks tidy. Cant say i even notice them now
    They work really really well
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    I'm in the process of replacing the rear door linings and the back sides with 1mm thick galv sheet steel. Just took off the old lining and used it as a template, got the grinder out and started cutting. Couple of coats of primer then black paint and it's come up real nice eh. Used self tapping screws to make my life easier. I can post up some pics when I'm done. Basically I went with metal for harder wearing and ease of cleaning, just attack it with the hose and done The cut outs for the speakers and door handle were easy enough to do, wasn't a job that would win any awards but the speaker covers etc cover up my rookie workmanship lol I will no doubt do the same to the front doors later down the track. One thing I like about it this idea is that when the panels get all roughed up I can unscrew, give it another lick of paint and it will look brand new again.
    Brett
  10. #8
    Expert Richo460's Avatar
    Cairns, QLD
    i bought my gq with ally checker plate trims, really don't like them though. They look really tacky so i am going to fit some original ones. My trims are screwed on, i suume new holes were made, probably self tapping screws.
    If you going through hell...Keep going
    GQ wagon locked - lifted - 33's, 02 SS ute, XB coupe 460bb, KTM530
  11. #9
    Quote Originally Posted by Richo460 View Post
    Have a go at painting them. Might come up a treat!
    Alternatively, swap sides with all your trims and the checker will be facing the door rather than facing out. You could then maybe look at covering them in vinyl??
    Paint could sort them out though? Even paint the backs as swap them as above
  12. #10
    Gold Coast,Aust.
    thanks for the pics mud...if any1 else has pics please post em...would like to see your handy work!!
    I'm too busy working and driving from the goldy to brissy at the mo, but when i do get a bit of time i'm gonna tackle the drivers door first at least..it looking pretty sad.
    I will post before and after shots to see what you think.hav'nt made up my mind which way to tackle this yet but i think the ply/vinyl idea sounds good.
