Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Connecting TV to 12 volt - Cable and connecting question
    583 Post(s)
    I have asked around many shops and Google and no one reallys knows the answer.
    I was given a little Conia LCD TV that I want to use in the camper. The previous owner had a 12 volt cable and ran this TV when he was camping, etc.
    I can get a cord that plugs directly into the TV using that little pin plug and to the ciggy socket but I can't find a cable that will run to the box first as I saw on a post in a camping forum that you need to run it into the box first.
    As far as I can see the box is a 240V input to 12V output converter for when using the normal three pin 240v connection.
    Does anyone know if you can completely bypass this by just getting a 12 volt cord directly into the TV or will this cause polarity issues???
    Hiya mate...
    You are correct, the box is only for AC operation.
    The Conia should run fine directly off 12 VDC. Just check to make sure you have the polarity correct (did the guy give you the lead he was using?)
    The only thing to watch is that you don't let the batteries get waay low or run it off unregulated solar which is too high... anywhere from 11 ish to 14 ish will be just fine
    99% of "off the shelf" 12 Volt leads will be centre pin positive and if you have a close look at the adapter box in the pic that is what the Conia requires
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    AB (27th May 2012)
    583 Post(s)
    Thanks ET, I was hoping you would see this post...haha
    The previous owner is touring around Australia at the moment and they kept the cord unfortunately.
    It will just be used to play the Wiggles for an hour before bedtime that's all....lol
    A wiggles fan eh... which one is your fav colour?
    No biggee not having the cord...
    If you want to make one up from stuff lying around pretty much any ciggy plug lead will do and you just need to solder on the appropriate size socket on the other end (Jaycar, Dickies etc will all have 'em) if soldering is out then a bit of a search will find "screw terminal" plugs
    If you need a quick off the shelf solution those retailers will all have el cheapo ciggy plug ins with about 6 to 10 interchangeable plugs on the other end, one of which should fit the Conia.
    I think the Conia will be 2.1 mm jack plug but don't hold me to that.
    583 Post(s)
    Thanks again mate, I'm not bad at soldering so will give it a whirl...Oh yeah, the blue one...LMAO
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Jaycar or similar should have a plug that suits your needs, reason why I say this as I just purchsed a 15" one for wifey next to the bed at home that is also 12v / 240v for use once we get our camper. Came through the mail last week and felt like a dufus as there were no 12v cables, rang them up and said the manufacturer does not provide them but are compatible with the generic 12v plugs as long as the input plug to the tv itself is the same. I am hoping to get to jaycar during the week to find 1
    www.swat4x4.com
    583 Post(s)
    Job done, soldered the wires to the plug and onto the socket....Works a treat!
    Wiggles in the bush here we come...LMAO
    Must be getting soft in our generation as my old man would never let us do this when camping as kids...lol
  10. #8
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    sorry mate have to agree with your dad,how are you or anybody else going to
    teach the young,s any thing about survival, 4x4ing fishing, they get all that at home
    and when you all go camping its time to empty your heads of all the stress around you
    im afraid if you you need to take tv,s ,microwaves into the bush they might as well
    stay in a caravanpark
    i know there only babies but agree with your dad
  11. #9
    583 Post(s)
    I haven't slept for 2 years Roofy...LMAO
    Nah it will just be for an hour before bed to settle the little bas$ard down....
    She's only 2 years old so it will only be for a year or so....Yep, who am I kidding!
  12. #10
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    This is what I think of T.V's on Camping Trips
    RAFLMAO Hope you take this as a Joke Mate.
    Now in my Day ............ LOL
  13. The Following 2 Users Say Thank You to Bob For This Useful Post:
    AB (19th June 2012), Sir Roofy (19th June 2012)
