Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: What do you think about Low Range Reduction Gears
    Oct 2010
    Old Bar, NSW
    I have a bit of a dilema, our patrols a fairly high geared and with mine do most difficult parts of tracks in low low.
    Other brands do the same in low 2nd, leaving them a crawler gear for the harder stuff and good engine braking down hill.
    I have been in situations where slipping the clutch and holding the revs at 2000 - 2500 is the only way to proceed.
    This has not happened often but abusing the clutch like that is not a good thing.
    So looking at reduction gears for the low box is raising more questions than answers, if you have a look at the spreadsheet attached it explains the possible benifits.
    If you have reduction gears can you post your opinions especially the effect on different terrains.
    The 65:1 would be awsome on the rocky climbs but what about the Canning Stock Route? It has 2nd gear matching the 1st in a stock set up.
    Appreciate your thoughts whether you have them or not.
    Cheers Macca
    Attached Files Attached Files
    Feb 2011
    Shed
    45 Post(s)
    I rekon any greater than 33" tyres ya need reduction gears. If you have an auto bloody good idea for downhill control. Im on 33's and reduction gears are on my wish list most definately
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    macca (11th May 2012)
    Oct 2010
    Old Bar, NSW
    Which set would you get?, I'm on 33's too.
    Feb 2011
    Shed
    45 Post(s)
    Wellllll eventually i want 35"s so the 85% are the way to go i rekon. Send big rig a pm if he doesnt read this thread he recently put a set in tank and is happy as a pig in poo
  7. The Following User Says Thank You to growler2058 For This Useful Post:
  8. #5
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    I have heard that if on 33' tyre stay to 40%ish reduction gears or if on 35' run 80%ish reduction gears depends on your main driving style if you do beach work prob only go 40%ish as you still need speed for momentum
    Such is the rule of honour.
  9. The Following User Says Thank You to macca86 For This Useful Post:
  10. #6
    Expert gec's Avatar
    Geraldton WA
    Me, I'd love a set of crawler gears, and I would also get the 85% and I have 33's.
    Western Patrol Club member
    GQ with 5.7 Gen 111 V8, Dual ARB airlockers, 33" Coopers, 9000lb Premier winch, Black Widow draws
  11. The Following User Says Thank You to gec For This Useful Post:
  12. #7
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by macca86 View Post
    mmmmmm "momentum is your friend" a mate runs a tough truck said to really consider the momentum issue. It applies in mud slippry tracks as well. Concerned about the CSR next year, climbing sand ridges could be a pain.
  13. #8
    Feb 2011
    Shed
    45 Post(s)
    Use high range if ya need momentum or use 4th and 5th in low
  14. The Following User Says Thank You to growler2058 For This Useful Post:
    macca (12th May 2012)
  15. #9
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Yep, 85% Marks Adapters in mine and simply the best (bar nothing) money I've spent on the truck. You need to weigh up your style of driving mate, but I have probably twice in my life used low range on sand ... Deflated tyres and high range has seen me never bogged to this day (and I would say I've beach driven at least 40-50 times on the beach at places like Fraser, Moreton, Bribie and Stradbroke Islands, as well as Rainbow beach, Woodgate - hard packed sand there though - and Anna Bay).
    In mud, low third definitely has enough momentum, and for rock crawling and down hill control, simply unbeatable.
    Not saying go 85's by any means though, as it sounds like you just need "a little more" low range gearing, and if that be the case, 43% would suffice for sure - absolutely more than noticeable ...
    Good luck with the decision and feel free to ask away if you think of anything else ...
  16. The Following 2 Users Say Thank You to Bigrig For This Useful Post:
    growler2058 (11th May 2012), macca (12th May 2012)
  17. #10
    Sep 2011
    adelaide
    18 Post(s)
    G`day Macca.
    Don't be concerned about the CSR I did it in 08 towing a camper trailer using stock gears
    Main thing on the CSR is tire pressures 18 to 24 PSI no higher. I ran 18 on the car and the trailer with no problems not 1 flat.
    Run these pressures from start to finish and take your time and you will not have trouble
  18. The Following User Says Thank You to pearcey For This Useful Post:
