Results 11 to 20 of 22
Thread: 12V cig socket + USB in centre console
    Feb 2012
    What is the input on them?
  4. #13
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    G'day Tweaked, I can't see a link in your post?
    Kris, if there isn't room for a surface mount female ciggy plug, you can get female ciggy plugs that do not need to be surface mounted, they just go onto the end of the wire - like a house extension lead. You could just let that rattle around in your console.
    You'd think there would be surface mounted ciggy and USB female plugs available - maybe that is what Tweaked is keeping us in suspenders about :-)
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  5. #14
    Tweaked's second post worked haha
  6. #15
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    That looks nice and neat Tweaked. What is the max amp draw through it combined? Would it be safe to simply beef up the original fuse for the ciggy lighter or would it be better to re-wire it in?
    tappin it
    Hello from Under Down Under!
  7. #16
    Feb 2012
    Yea sorry about that it didnt come up in my first post stuffed it up
    Here is some specs on it:
    1 x Dual USB Sockets univeral charger.
    1 x Ciga Socket
    Compatible for all generation apple iPhone, iPad and iPod
    LED indicated power ON
    Black colour PVC casing
    reverse polarity fused protection
    Specification
    Input Voltage: 10-20v dc
    Input power protection fuse: 2A
    Max output power: 1Amp
    Max charging output 2 x iPhone, 2 x iPod or 1 x iPad
    Surface Mount
    C/W PVC housing
    Designed for heavy duty use
    Specially designed power socket to suit 2 USB powered devices & additional cigarette lighter socket
    I personally would wire up seperate to the factory cig. I have different combinations of these available as well
  8. #17
    Have you got something like that which also has a USB input? Would be perfect if you do.
    Tappa tappa
  9. #18
    could one of the usb sockets be rewired to accept the usb extension from the headunit?
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
  10. #19
    Feb 2012
    I will see what I can find for you mate
  11. #20
    Cheers mate, appreciate it.
