13th April 2012, 12:10 AM
Long Range Fuel Tank interior access and sound proofing
Well I'm about 75% done with putting down the sound proofing and I was looking at Long Range Fuel tanks both main and sub... There is a disclaimer/warning on two mfg sites, need access to inside of vehicle. Soo... I'm assuming they mean access to the two ports in the floor, which we've covered, but cut around and exposed the four nuts on each plate. Am I missing something else? After a day or two of putting this stuff down with a heat gun you can't get the stuff off very easily (ah learning a thing or two the hard way).
Scott
2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
13th April 2012 12:10 AM
13th April 2012, 12:15 AM
Daily Lurker
what sort of truck do you have mate? can you take a pic or 2 of the job? i need to do the same to my car and would love to see what you have done?
13th April 2012, 09:11 AM
Rusty_Nail,
There should be some pictures posted of the work in progress in the 'My Rides' threads, if not I can re-post them. I had to put the front seats back in to run errands but working on rear portion, hopefully complete in the next couple days as I'd like to see how quite it is on a run to Costco in Canberra next Tuesday.
2004 GU 4.2 ST
Scott
18th April 2012, 09:46 PM
Rusty,
Were you able to see the pictures..? I'll probably add a few more tonight in the DIY forum.
18th April 2012, 09:54 PM
Moderator
Basically if there is a hatch in the floor pan it will be to get to the sender. Worth keeping access or if you ever need to you can just drop the tank to get to it. You can make that descision mate. No big deal really. You may never need to get to it
Check out my Toy -->
Rogue Dung Beetle
10th May 2012, 05:14 PM
Might be a good excuse for me to buy a long range tank prior to completeing my interior sound deadening, easier install It doesn't really take much of an excuse for me to want things though.
