31st December 2011, 05:54 PM
manual transmission
hi guys , anyone out there had trouble with first gear not wanting to be select , basicall.y have to stop to engage 1st. could incorrect oil cause this or is it as I suspect the syncro ring and a gearbox rebiuld
31st December 2011 05:54 PM
31st December 2011, 06:10 PM
Administrator
Could be the syncros mate but when was the last oil change.
I would be doing the oil change first with good quality and see if that helps first.
patch697 (31st December 2011)
31st December 2011, 07:00 PM
Whats the clutch peddle feel like? Its also a symptom of a failing clutch master or slave.
31st December 2011, 08:24 PM
Mine has always done this. - 02 Series 3 ZD. Never worried about it. Never need to use 1st gear until you come to a complete stop anyway....
31st December 2011, 10:00 PM
Yep, I would go with the oil change first. Make sure you use a GL4 oil not a GL5. A GL 5 will completely stuff your syncros, and it will do it quite quickly. Go here for a read: http://www.nissanpatrol.com.au/forum...oil-GL4-vs-GL5
