Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: RE4R03A Gearbox Rebuild
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Well the reason for the gearbox rebuild was due to loosing everything above 2nd gear.
    Manuals / Part breakdowns that I used can be found here: http://www.nissanpatrol.com.au/forum...851#post143851
    Cost to repair
    Gearbox
    Master Rebuild Kit - $643.00
    RE4R03A Gasket, Seals & Ring Kit
    Band
    Oil Filter
    Full Set Of Clutch Frictions
    Pump Brush
    Change Over J6 Torque Convertor - $395.00
    Refundable Deposit on Torque Convertor - $250.00
    Freight - $60.00
    Total: $1348.00
    Automatic Transmission Fluid
    Syntrans SYN III G/H 10W 20LTR - $125.40
    Total: $125.40
    Consumables
    Emery cloth GP 180 grit x 50mm ( 50mtr roll ) - $34.53
    Lanotec Citra-Force 750ml spray bottle x 2 ( wanted 1LTR but nobody local had stock - $ 36.37
    Wet-Dry Sheet 9 x 11, 120 grit x 6 - $6.02
    Total: $76.93
    Total Cost Of Rebuild to Date - $1550.33 including GST
    Rebuild Kit and Convertor supplied by:
    Wholesale Automatic Transmissions
    1/58 Barry Street
    Bayswater, VIC, 3153, Australia
    03 9762 8108
    Consumables supplied by:
    Nepean Boltmaster - Penrith Branch
    42 Borec Road
    Penrith, NSW, 2750, Australia
    02 4722 3034
    Automatic Transmission Fluid supplied by:
    Gulf Western Premium Quality Lubricating Oil ( Aust )
    1 Coombes Drive
    Penrith, NSW, 2747, Australia
    Phone: 61 2 4732 3305
    Sales: 1800 248 919
    Rebuild Kit has arrived
    20ltr of ATF
    Emery cloth, Wet-Dry sheets, Lanotec Citra-Force
    Tags:
    Auto gearbox failure
    Aug 2010
    17 Post(s)
    Day 1 - Why didn't I just pay a mechanic 2 do this!!!
    The day didn't go as planned, we didn't get the gearbox out, but tomorrow is another day.....
    Had a bit of trouble removing the hand brake drum / 4wd selector / Rear tail shaft, they just didn't want to come off....
    The day begins 4b up on stands
    Draning the gearbox oil - mmmm smelt a bit burnt
    Text 2 follow..........
    10092011374.jpg 10092011376.jpg 10092011377.jpg 10092011379.jpg 10092011378.jpg 10092011384.jpg10092011383.jpg 10092011380.jpg 10092011385.jpg 10092011387.jpg 10092011386.jpg 10092011390.jpg 10092011391.jpg10092011389.jpg 11092011393_1500x2000.jpg 11092011394_2000x1500.jpg 11092011395_2000x1500.jpg 11092011396_1500x2000.jpg
  3. The Following 4 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    FNQGU (15th May 2014), mongol box (18th November 2011), Sir Roofy (15th September 2011), snicko (12th October 2011)
    Aug 2010
    17 Post(s)
    Day 2 - Gearbox comes out - The strip down begins
    Well today was a bit more eventful than day 1, Gearbox dropped out pretty easy, gave it a quick bath with the pressure washer before starting 2 strip it down. Found a lot of metal on the magnet in the pan Also found a broken wire in the valve body ( not 2 sure what the wire is 4 yet ).
    Below - Gearbox coming out
    11092011397_2000x1500.jpg 11092011399_2000x1500.jpg 11092011400_1500x2000.jpg
    Below - Removing the torque convertor and draining it
    11092011401_2000x1500.jpg 11092011402_2000x1500.jpg 11092011403_1500x2000.jpg
    11092011404_2000x1500.jpg 11092011405_2000x1500.jpg 11092011406_1500x2000.jpg
    Below - A quick bath.......the cleanest its been in years
    Below - Transfer Case after a bath
    Below - The strip down begins
    11092011409_1500x2000.jpg 11092011410_1500x2000.jpg 11092011411_1500x2000.jpg 11092011412_2000x1500.jpg 11092011413_2000x1500.jpg 11092011414_2000x1500.jpg 11092011415_1500x2000.jpg
    Below - Metal Anyone???
    11092011416_2000x1500.jpg 11092011417_1500x2000.jpg 11092011418_1500x2000.jpg 11092011419_1500x2000.jpg
    Below - The Valve Body getting removed.....found a broken wire
    11092011421_1500x2000.jpg 11092011422_1500x2000.jpg 11092011424_1500x2000.jpg 11092011425_1500x2000.jpg
    Below - Valve Body removed
    Below - Main Case and the internals
    11092011429_2000x1500.jpg 11092011430_1500x2000.jpg 11092011431_1500x2000.jpg 11092011432_2000x1500.jpg 11092011433_2000x1500.jpg 11092011434_1500x2000.jpg 11092011435_1500x2000.jpg 11092011437_1500x2000.jpg 11092011438_2000x1500.jpg 11092011439_2000x1500.jpg 11092011442_1500x2000.jpg
    Below - Can't really see it in the pics but some of the friction plates are know longer friction plates they are metal to metal!
    Below - The mess
    Below - Having a Hydrualic Press, just makes it so much easier
  5. The Following 5 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    Ade (16th September 2011), FNQGU (15th May 2014), Silver (12th September 2011), snicko (12th October 2011), Woof (16th September 2011)
  7. The Following 6 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    canuck (26th November 2011), FNQGU (15th May 2014), mongol box (18th November 2011), ripper (22nd October 2012), Sir Roofy (15th September 2011), snicko (12th October 2011)
  8. #5
    Aug 2010
    17 Post(s)
    Day 4 - Waiting for parts
    Today was pretty much an uneventful day, was waiting on an email back from Wholesale Automatic 2 see if he had some parts that we needed. We got a hold of him after lunch and he said he had the parts but he needed 2 pull them out of a gearbox that he has there.
    Went shopping for a Tap, tapered grub screw, and puller.
    Could not source the puller we wanted so are getting one made up from a metal fabricator down the road from my old mans.
    Text 2 follow
    14092011477_1500x2000.jpg 14092011478_1500x2000.jpg 14092011481_2000x1500.jpg
  9. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  10. #6
    Aug 2010
    17 Post(s)
    Day 5 - Valve Body Strip Down
    Still waiting on parts, but at least now I know Wholesale Auto has them all, won't turn up till Monday......was kinda hoping that we would have the box out, rebuilt and back in this week while I was on holidays, not going 2 happen, will have 2 wait till next weekend now
    Used the time to strip the valve body down today and clean it up, so many parts in such a relatively small valve body *L*
    15092011482_1500x2000.jpg 15092011483_1500x2000.jpg 15092011484_1500x2000.jpg 15092011485_2000x1500.jpg 15092011486_2000x1500.jpg 15092011487_1500x2000.jpg 15092011488_2000x1500.jpg 15092011489_1500x2000.jpg 15092011490_1500x2000.jpg 15092011491_2000x1500.jpg 15092011492_1500x2000.jpg 15092011493_2000x1500.jpg 15092011494_2000x1500.jpg 15092011495_2000x1500.jpg 15092011496_2000x1500.jpg
  11. The Following 3 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    FNQGU (15th May 2014), Sir Roofy (15th September 2011), snicko (12th October 2011)
  12. #7
    Aug 2010
    17 Post(s)
    Day 6 & 7
    Day 6
    Spent most of the day fart arsin around with the valve body, putting it back together, unfortunately we never measured the springs when we took them out and the spring dimensions we have do not match the manuals spec sheet *L* had a good guess, will soon find out it we were right or not *LMAO*
    Below - The spec sheet........mmmmmmm dimension does not match my springs, oh well........... lets put this spring here anyway!
    Sorry guys didn't take any other pics 2day.......was 2 busy holding a scotch in my hand
    Day 7
    Just another day I say 2 myself why did I want 2 do this for......
    Day started ok, then turned 2 crap
    More text 2 follow, after the following bottle of bourbon
    24092011500_1500x2000.jpg 24092011501_1500x2000.jpg 24092011502_1500x2000.jpg 24092011503_1500x2000.jpg 24092011505_1500x2000.jpg 24092011514_1500x2000.jpg 24092011517_1500x2000.jpg NewCoverfromWholesaleAutomatics.jpg OldCover2.jpgNewCoverfromWholsale-Holes.jpg ValveBodyGasket1.jpg ValveBodyGasket2.jpg ValveBodyGasket3.jpg ValveBodyGasket4.jpg
  13. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  14. #8
    Aug 2010
    17 Post(s)
    Day 8 and 9
    Day 8 - Clutch assembly day
    25092011518_1500x2000.jpg 25092011519_1500x2000.jpg 25092011520_2000x1500.jpg 25092011521_1500x2000.jpg 25092011522_1500x2000.jpg 25092011523_1500x2000.jpg 25092011524_2000x1500.jpg 25092011528_1500x2000.jpg
    Day 9 - Clutch assembly day........again
    Relising we had put the wrong springs into one of the clutches the day before and not remembering which one we had put them in cased a strip down of rebuild again *L* oh the joys
    01102011540_1500x2000.jpg 01102011542_1500x2000.jpg 01102011543_1500x2000.jpg 01102011544_1500x2000.jpg
    01102011545_2000x1500.jpg 01102011546_2000x1500.jpg 01102011547_2000x1500.jpg 01102011548_2000x1500.jpg
  15. The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    FNQGU (15th May 2014), snicko (12th October 2011)
  16. #9
  17. #10
    Aug 2010
    17 Post(s)
    Saturday 8th October 2011 ( Day 11 )
    Arrived at my parents bright and earlier, let the fun and games begin
    Below: Valve body in, oil pan on.....time 2 install, fat chance..........pan is just sitting on there 2 keep any dust out, Still waiting on the valve body 2 be bolted in.
    Below: Getting ready 2 solder the broken wire back on the Fluid Temperature Sensor
    Below: Evidence the previous owned had the gearbox out for some reason
    Below: Oil pump bolted up
    Below: Valve Body going back in
    Below: Gearbox going back in
    08102011587_1500x2000.jpg 08102011588_1500x2000.jpg 08102011592_2000x1500.jpg 08102011594_1500x2000.jpg 08102011595_2000x1500-1.jpg
    Below: Why is my back wet!!! The only part of the driveway that got wet under cover, right where I put my car on the stands! Rain rain go away!!!
  18. The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    Forest1970 (18th December 2012), pluhart (28th December 2018)
