Results 1 to 10 of 16
Thread: Electrical Water Temperature Senders - How To Test Folks?
    475 Post(s)
    G’day NP.com.au Team,
    Electrically challenged skills I do have and are hoping for some guidance on a possible NPT Yanky water temperature sender issue believed found for a custom aftermarket nuffy need.
    As best as I can find tonight the additional silly Yanky dual fan module appears to be powered up yet still no action even on the old trucks first 90C Craig Davies Fans historical settings as always before!
    All roads nuff nuff logically (I think) point back to the Yanky sender, is there kindly anyway to mechanically/electrically test its funkationality?
    Many thanks!
    Mark
    Mark is the sensor two wire or single wire mate? If single it should just be a simple switch, on (at the set temp) and off. So if you heat some water to the set temp, attach a DMM to the thread and then to the wire, if the switch is working it should trigger at the set temp. Should. Lol.
    MB (9th October 2019)
    475 Post(s)
    Thanks Mark mate, appreciated!
    Think it is single wire so I’ll give that a go tonight @matfew sparky is in the hills later this evening too so might be able to handball this task to him
    Yeah should work in theory. It works on the similar principle to an oil pressure switch, but is activated by heat. The switch is just an earth contact for the fan.
  8. #5
    Any luck mate?
    MB (11th October 2019)
  10. #6
    475 Post(s)
    Haven’t had a crack myself yet mate and poor old Matfew has been flat out like a lizard drinking, 4:00am starts the poor bugger!
  11. #7
    I have to drop off parts to a customer in Yarra Glen in the morning. I can drop past and take a look if you like.
  12. The Following User Says Thank You to mudski For This Useful Post:
  13. #8
    475 Post(s)
    That’d be awesome, thanks mate
  14. #9
    No worries. I'll call you in the morning.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #10
    330 Post(s)
    Yeah you would test that the same way as a thermostat in a pot. Test to boil.
  17. The Following User Says Thank You to MudRunnerTD For This Useful Post:
