26th February 2013, 12:20 PM
Throttle issue
Ok I have a 2007 patrol wagon st-s auto crd it has erratic rpm issues especially
Always between the 1500-2000 mark normally if I am cruising not revving up or any load
The tacho needle would flicker about a few hundred rpm here and there with the egine gaining power then losing it but not on cruise control it's not a huge problem just annoying
26th February 2013 12:20 PM
26th February 2013, 12:23 PM
Mate pop over to the introductions first hey, just something the forum asks from everyone
26th February 2013, 12:36 PM
hay mine started to do similar on a new CRD 2012, only when cold though
SHINY AND NEW: 2015 Series 2 Y62 Ti in White. Bone stock, hate to say it but its the wifes car this time.
OLD SOLD:Silver 50th Anniversary Patrol, 2" Pro-Comp Lift, 32" MT ATZ 4 Rib, 9000lb Warn Winch, UH7700NB + BT UHF Brilliant. Ultra Gauge and some GO FAST bits........
26th February 2013, 12:50 PM
Re: Throttle issue
Aussies1129
threedogs
After you've done that, have a quick search of the forum(top right corner). There's been a couple of threads started with the same issue. Hopefully you will find some help:-)
FanTapstic!
Hello from Under Down Under!
26th February 2013, 02:34 PM
26th February 2013, 03:53 PM
No worries thanks guys will do cheers
26th February 2013, 04:38 PM
mine did the same thing, turned out to be the accelerator pedal which i have replaced and since then has been great. you can get them from nizbits for around $460 plus postage or you can do what i did and ring nissan and they will quote you $570 and then you can say that you can buy them for $440 from nizbits and they should match the price then you save on the postage, cheers....
2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
26th February 2013, 05:22 PM
#8
Definitely sounds like the TPS Sensor is playing up. (Throttle Position Sensor)
You may be able to pull it apart to clean the contacts. There is another thread about which details how to pull it apart to clean...it doesn't take too long, and might save you a few dollars ( or at least become a useable spare part to take on longer trips away )
Mic
26th February 2013, 05:36 PM
#9
sounds like it might even be the gearbox dropping in and out of overdrive or the torque converter locking and unlocking !
26th February 2013, 09:50 PM
#10
Thanks guys I appreciate the response awesome I will try with the throttle position sensor on
The pedal first and go from there cheers
