26th February 2012, 02:04 PM
need help bleeding/fixing brakes on a GQ
Hi all. I've run out of ideas, and am now into the 'gaining experience' zone, except I don't know what experience to gain. I hope someone can help.
1. I replaced the brake cylinders on the rear wheels (drum brakes), and drained all the brake fluid while I was at it.
2. I added new fluid, and bled the system until new clean fluid was coming out at each brake cylinder.
3. after two attempts to get rid of all the air, I discovered that there is a fifth bleed point in the rear axle (power transfer valve), and bled the whole system again.
4. the pedal is still unacceptably spongy (over half the pedal travel is 'soft'), so I bled the entire system again, but found no air; and made no change to the pedal action.
can anyone suggest what might be wrong, and how I can fix it?
many thanks
26th February 2012 02:04 PM
26th February 2012, 02:09 PM
Banned
Sounds like one for Tony, Patch and crew ... hang tight mate, they'll be along to assist no doubt!!
26th February 2012, 02:30 PM
Hardcore
Have you adjusted the rears up?
Start bleeding at the rear left, power valve, rear right, then front left then front right, don't push the pedal all the way to the floor, lock the bleeder before letting the pedal back.
Sometimes it needs a "gravity" bleed where you open the bleeder and let the fluid bleed itself.
Have your catchment bottle higher than the bleeder using beverage tube to the bottom of the bottle.
Bleed the master cylinder several times.
You may need a "pressure" bleed if all else fails.
Cheers, the ferret.
26th February 2012, 03:04 PM
I was careful not to change the adjuster on the rears - just made sure they were free to turn.
for bleeding, I used a non return valve on the bleed tube, but when I struck trouble I went back to the karate kid method (brakes on....brakes off)
last time around, I pumped about half a resovoir through to the load adjuster valve to try to shift any air locks.
since starting this post, I checked the connector at the top of the master cylinder, and had a fluid leak the instant I cracked it - but there is a downside up u bend just above this point - perfect for a hard to shift air lock.
what do I need to get to do a pressure bleed?
26th February 2012, 03:10 PM
Hardcore
Try Supercrap.
I think they sell a kit, but try the old gravity bleed method first.
If you still want to pedal bleed it, just go steady and don't pump it like a rabbit scratchin flees!!
Cheers, the ferret
EDIT.
There may be more than one bleeder on the load sensing valve.
26th February 2012, 04:14 PM
thanks
will check the valve - but I think it only has the one on the top.
I have the visibleed tube - and this is what I used to begin with.
Am starting to think I might put this back on to one of the rear brake lines, and try to pressurize the resovoir with my mini compressor - I think the most likely culprit is an airlock somewhere early in the system. Everything was good until I fixed it.
26th February 2012, 04:37 PM
Hardcore
If the pedal won't hold pressure and slowly goes to the floor, then you may have a leak, or the master cylinder needs an overhaul.
Cheers, the ferret.
26th February 2012, 05:44 PM
#8
The pedal goes half way under light pressure, then goes hard and starts to apply the brakes. once it is on hard, it goes no further
26th February 2012, 05:55 PM
#9
Hardcore
So The master cylinder is ok, you still have air in the system, more bleeding needed.
Adjust the rears up tight and bleed system again.
Check that no hoses are expanding when the brakes are on hard.
Cheers, the ferret.
26th February 2012, 06:15 PM
#10
