Results 1 to 10 of 13
Thread: Rear Axle vibration
    Rear Axle vibration
    Guys,
    Have checked through and not found an answer for this and wondering if someone else has had this problem before.
    I have had my wheels balanced and am happy that they are okay. On the freeway at 110 the rear axle starts to vibrate and causes the rear wheels to bounce for about 2 minutes then it will stop and i can go up to 130 without any vibration for about 2 or 3 minutes then it comes back and I have to slow down to about 106km.hr to avoid the vibration until it passes again.
    Anyone here had that problem? Could it be simply the shockies?
    Have checked the wheel bearings and they are okay.
    The centre drum brake appears to grab the drum slightly in one spot so i'm getting new shoes and will get that machined out...
    Any thoughts guys? Thanks
    Maybe an out of round tyre mate?? Very strange
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Rear shock/shocks??
    Tail shaft could be out of balance
    581 Post(s)
    What size tyres and lift are you running also mate?
    Expert Benno7's Avatar
    Nov 2010
    How are your tail shaft uni's ? Try swapping the rear wheels to the front and check your shocks for any damage.
    First thoughts are an out-of-round tyre. Swap the rear wheels to the front (or borrow another pair) and see if the problem goes to the steering wheel. Next check the shockies and all the rubber bushes in the control arms. Also check that the pinion shaft and nut aren't loose, that the tailshaft bearings aren't flogged or seized, the flange nuts loose or that the 2 halves of the tailshaft are aligned correctly. Deevo
    Nov 2011
    Townsville
    I have had my new tyres ballanced three times by one of the biggest tyre chains in the country because of vibration only to take it somwhere else for them to tell me that thay wont ballance my tyres because they are not round. moral of the story is some dude (normally on parole) can ballance your tyres ond they will come up 00 on the machine but if they aint round it counts for sh-t
    so make sure they check
    cheers Andrew
  10. #9
    Expert Kelvinator's Avatar
    Aug 2011
    maryborough and gladstone queensland
    Check panhard rod bushes, had that before, also check if its bent. Makes the strangest vibration at times. But i'd mainly check your driveshaft being that intermittent, if youve ever watched a washing machine vibrate like crazy then come good then vibrate again while the load is of centre, thats what a buggered tailshaft/unis acts like. Also my other immediate thought was brakes so your could be onto it there. And you can check for out of round tyres by jacking the wheel a mil off the ground on a flat floor and spinning it. if it contacts or the gap widens you may have an issue.
    Hope that helps dude
    Flip er on er wheels, she'll run!
    4.2 Diesel GQ 4" King'n'ProComp Lift, 33's, Gu steer box conversion, custom drawers and a heavy right foot. Turbo kit, quarter chop and a heap of barwork coming very soon!
    A BIG thanks to Johnny at Repco Northside Rocky for always sourcing me the gear and parts I need ASAP You've saved me many times.
  11. #10
    Hardcore
    central coast nsw
    If your tyres have gone out of round very good chance, your rims will also be out of round.
    Especially so if on rear end as they do the least work.
    When you try Kelvinator's advice set up a jig beside rim to also check for rim movement.
    Bend up a coat hanger straighten hook to become a pointer and weight it down beside rim might be the go
    Maybe tyres Out of round tyres giving worn shocks a hard time if ya follow.
    I agree other possibilities could be at play here also, uni joints etc.
    let us all know how ya go.
