Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Will 35's fit with a 2' lift?
    Penrith
    I was just watching one of the 4wdtv vids on here and saw a segment where they were fitting 35's to a GU and said with lift you can but need either a radius arm spacer kit or longer radius arms themselves to stop scrubbing and breaking guards, They did not however say how big the lift needs to be to start with? I run 33 MTZ's now and under big flex (for standard hight) it already scrubs. My question is, is a 2" lift enough with the Radius arms/ spacer kit enough to accomidate the 35's?????
    Thanks Patroler's
    Probably not. My brother in law has a 3" lift in his GQ and 35s were scrubbing a little bit. Could be different on a GU but I think it's pretty similar.
    Ben81C (23rd March 2012)
    GU Wheel arches are Massive and Much bigger than a GQ. I run 35s with a 3" lift on my GUIV with no trouble at all. I have removed the front mudflaps but had to do that for the 33s and no lift. went to 35s and a 3" lift with Drop boxes instead of just spacers (same position though) and have only scraped once on a big hit
    All good
    juanpinas88 (1st September 2013)
  7. #4
    Penrith
    So 3" lift required to run 35's??
  8. #5
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Theres also body lifts and coil spacers to put into the equation.
    Sent from my LT18a using Tapatalk
    Hello from Under Down Under!
  9. #6
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    heres mine with 2inch lift and 35s i had no problems running these tyres on my gu
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  10. The Following 2 Users Say Thank You to patrol2.8 For This Useful Post:
    Ben81C (23rd March 2012), juanpinas88 (1st September 2013)
  11. #7
    Penrith
    So it can be done, no probs with scrubbing then? Did you just have 2" springs and shocks or coil spacers/ body blocks as well. I am put of by the price of a complete 3" kit and want to do it properly, thats why the questions about 2" lift. This way i can get a really good quality set up. I just seam to find deep ruts and i think 35's would get me through a lot of them.
    Thanks, as they say a pic says a thousand words.
  12. #8
    Nov 2011
    vic
    Ben81c my car runs an ome suspension with remote nitro charger cylinders giving it a total of a 2'' lift has no spacers or body blocks etc i ran these 35s for a couple of years without scrubbing or any other problem thereason i dont have 35s now is my car is a 2.8 and at the time i didnt have some of the mods i have now and the tyres just really didnt suit it so i went down to 33s which suit me better now anyway as im doing more touring than going out for a days 4wding in the bush ive put up some more pics i found when i firs tput them on and wanted to see how they would go
  13. The Following 2 Users Say Thank You to patrol2.8 For This Useful Post:
    Ben81C (24th March 2012), juanpinas88 (1st September 2013)
  14. #9
    brisbane
    ill be puttin on some 35s on the weekend from a mates gu ill get some pics and see where it scrubs if any and let u know.
    i have a 2" lift with no radius arm spacers .
  15. The Following User Says Thank You to megatexture For This Useful Post:
  16. #10
    Advanced snowy's Avatar
    Adelaide
    im running a tyre equal to a 34 with a 2 inch lift with no spacers and it does not appear to go anywhere near rubbing so id imagine a 35 should clear. Especially on a gu
  17. The Following 2 Users Say Thank You to snowy For This Useful Post:
