Results 11 to 20 of 38
Thread: Will 35's fit with a 2' lift?
    Penrith
    2" it is, that's gold. I was hoping they would. Thanks all.
    Perth WA
    61 Post(s)
    I ran 33" with my 2" Old Man Emu lift on the 2007 GU and they rubbed.
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  4. #13
    Patrol Freak hekarewe's Avatar
    Feb 2011
    springfield lakes
    just went and brought 285 75 16 for my gu with a ome 2 inch lift have not put them on the car yet but would be intested if anyone else has this size on the same on that lift if they have had any issues with scrubbing
  5. #14
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by hekarewe View Post
    285's are equivalent to 33inch. You shouldn't have any dramas at all. A mate has a GU with 2 inch lift and 33s no problem:-)
    tappn it
    Hello from Under Down Under!
  6. #15
    Feb 2011
    springfield lakes
    tappn it
    fantabulous!!!!!! although i have found one minor prob with mounting spare,,,,,, tyre touches the rear windscreen wiper shaft hopefuly wont interferre with it.
  7. #16
    Aug 2011
    North West Tas
    56 Post(s)
    You might be able to put spacers on the studs of the spare tyre carrier and still have enough thread to mount the tyre. Or you can take of the wheel carrier and put a spacer between it and the door panel
    tappn it
  8. The Following 3 Users Say Thank You to taslucas For This Useful Post:
    growler2058 (24th March 2012), hekarewe (24th March 2012), juanpinas88 (1st September 2013)
  9. #17
    22 Post(s)
    Quote Originally Posted by Ben81C View Post
    . My 35's sometimes scrub on a 4 inch lift with drop radius arms.
    I think it will scrub on the rear at full compression.
    96 GQ coil/Cab
    08 G6eT
  10. #18
    Feb 2011
    springfield lakes
    mounted up the tyres and so far so good no rubbing lock to lock off road will tell,,, as for the spare i will invest in a spacer to go between the carrier and the door that way when i wear this suspension set and move up to a 4 inch lift i can then mount my 35 inch tyres LOL
  11. The Following User Says Thank You to hekarewe For This Useful Post:
  12. #19
    Perth
    Im running 33's on the troll and on full flex they are scrubbing the under side of the guard but miss mudflaps. Theres about 5mm between tyre and lip.
    No way I could run 35's without lift
  13. #20
    brisbane
    put some 35"s on today and they rub slightly but no more then my 33s on road but on full flex they rub on the fuel filler guard on rear right side and on front mudflaps.
    i think with radius arm spacers the front won't rub and the rear guard can be reshaped with a lil heat as its only plastic so all in all ill be gettin some 35s for sure!
    it wasnt even on full lock that they rubed but on 3/4
    u can see the 31s vs 35s in 2nd pic
  14. The Following User Says Thank You to megatexture For This Useful Post:
