Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Air Intake Pipe/Hose GQ Patrol/Maverick
    581 Post(s)
    Yep, I just ended up welding a 100mm round pipe to the square outlet and used bits of steel to block the holes off and welded them on...
    Check out this link below...
    http://www.nissanpatrol.com.au/forum...pipe%26quot%3B
    Another way would be to utilize the existing square to round adapter that you already have and somehow connect the two round pipes up. Maybe using some sort of harder joiner and use 2 x pipe clamps???
    Maybe a same size OD pvc pipe only 100mm long and force the two pipes over the PVC and hose clamp....Not sure PVC would be the go with engine heat but something similar to that which can handle heat.
    Jul 2020
    Hi guys did anyone come up with a conclusion for this missing pipe? I'm missing the same one and will attach pic for reference. I've looked online and can find some on ebay but nowhere else.
  4. #13
    Jul 2020
  5. #14
    Jul 2020
    Patrolaparts.com sell them but they aren't cheap
  6. #15
    Jul 2020
    Thanks Davo, ive tried that website but its not working atm? I have had to reorder the pipe as the one ive pic abouve was for the desiel version and not the petrol motor. The petrol version is about half the size and dosent have a bend in the pipe.
  7. #16
    Jul 2020
    I can't figure how to post pics. It's $100 odd for the tb42. Part no is 6286002J00
