Results 1 to 6 of 6
Thread: Trans temp gauge on 2010 CRD auto
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    I've just got a oil temp gauge so I can keep an eye on the trans temp - any ideas on the best spot to put the sender?
    Jon
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by TheFlyingBadger View Post
    I thought these alteady had a sensor in them....I coulld be wrong but I'll double check
    ________________________
    ______ 2017 D-Max _______
    Oct 2010
    Perth
    Quote Originally Posted by NissPat View Post
    Ta Pat. I cant even look to see what's there at the minute, I'm away from home for a while....
    Jon
    ACT
    OK, This might help. Pages from the manual. You could tap into the sensor circuit and should be able to display temps with a gauge. I have tried thin on a scan gauge without any luck but I'm pretty dumb when it comes to programming TXD/RXF/MTH...bla,bla, bla...LOLOL
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    You should be able to get a trans temp reading from a good OBD reader. I get it from Nissan Scantech on my car pc, but I have a non OBD Di Patrol.
    That way you'll be reading what the TCU sees.
    Oct 2010
    Perth
    I've not managed to get it on the scanguage, nor has anyone else I've seen on t'interweb. Out of interest, what sort of range of temps are you seeing?
    Jon
