22nd March 2012, 03:18 AM
Trans temp gauge on 2010 CRD auto
I've just got a oil temp gauge so I can keep an eye on the trans temp - any ideas on the best spot to put the sender?
22nd March 2012 03:18 AM
22nd March 2012, 05:07 AM
SUCH IS LIFE
TheFlyingBadger
I thought these alteady had a sensor in them....I coulld be wrong but I'll double check
________________________
______ 2017 D-Max _______
22nd March 2012, 06:29 AM
NissPat
Ta Pat. I cant even look to see what's there at the minute, I'm away from home for a while....
22nd March 2012, 07:18 AM
SUCH IS LIFE
OK, This might help. Pages from the manual. You could tap into the sensor circuit and should be able to display temps with a gauge. I have tried thin on a scan gauge without any luck but I'm pretty dumb when it comes to programming TXD/RXF/MTH...bla,bla, bla...LOLOL
23rd March 2012, 07:18 PM
You should be able to get a trans temp reading from a good OBD reader. I get it from Nissan Scantech on my car pc, but I have a non OBD Di Patrol.
That way you'll be reading what the TCU sees.
23rd March 2012, 08:19 PM
I've not managed to get it on the scanguage, nor has anyone else I've seen on t'interweb. Out of interest, what sort of range of temps are you seeing?
