28th April 2012, 12:39 PM
#11
teno45
Hey mate, if you don't mind me along, what did this cost you?
hi sounds silly but it was either $235 or $265 cant find invoice because i purchased temp kit and a manual lock up kit for the trany at same time we are going to be doing some heavy towing so wanted to watch temps and engage lock up whilst towing to bring temp down
28th April 2012 12:39 PM
28th April 2012, 02:37 PM
#12
fishnsurf
Thanks mate. gives me a ball park figure, Dont do a huge amount of towing myself so dont know whether its worth it or not. Whats involved in the manual lock up kit?
Teno's Troll...
08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
28th April 2012, 06:42 PM
#13
teno45
Have a look in the DIY for a thread on manual torque converter
tappin it
Hello from Under Down Under!
28th April 2012, 07:58 PM
#14
Fishnsurf, have you got any pictures of the install? I have the sender and gauge, need the adapter for the trans.
28th April 2012, 11:10 PM
#15
teno45
There's a new DIY thread where the photos actually work now
1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
20th September 2012, 10:58 PM
#16
outbackjack
Has anyone got a picture or two for the install of the sender for Auto Temp?
I am thinking that you put some elbow joiner at the inlet to the radiator from the Trans.
I'm after some aftermarket sender photos now too, if anyone has some.
If I understand correctly, I might need to drill through the Banjo Bolt that holds the cooler line onto the transmission, and then tap a thread into the bolt. Hopefully it's as simple as that.
A photo of one from wholesale Autos would be great, but I want to use a digital gauge rather than their analogue one, and I'm hoping to do it cheaper too.
21st September 2012, 08:36 AM
#17
Legendary
could you use one of these then just bolts onto housing
http://www.ebay.com.au/itm/NISSAN-PA...item2a22092c65
2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
OH LEATHER IS NICE
21st September 2012, 02:15 PM
#18
my third 256
Don't think I'd trust that for transmission temps, because it's the ATF/coolant itself which is damaged by heat, and I think it can change quickly. That flat display could be good though. It might fit nicely on the steering column.
For engine temp I think it'd be okay, because it'd warn you if the temp was rising. I think the only time engine temps rise quickly is with coolant loss, and no temp gauge is fast enough to warn you of that.
I've been planning to put in a coolant loss/oil pressure alarm, and should probably do all of this as one project.
PS. Just noticed your signature "OH LEATHER IS NICE"
From what I've seen in cars, leather is just a poor substitute for vinyl :-)
21st September 2012, 11:47 PM
#19
I made up mine here http://www.nissanpatrol.com.au/forum...d-temp-display
I just taped the sensor onto the outlet cooler pipe. Runs 60 ish deg most of the time. Cost me about $60 but thats for battery volts and 5 other temps too.
2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
22nd September 2012, 02:25 AM
#20
adventurepaul
I made up mine here
That's awesome, except that you've probably just given me a heap of work to do
Do you have a photo of that?
I'm guessing you've heard of the Raspberry Pi?
EDIT: Well now I feel dumb.
Just realised that I read "taped the sensor onto" as tapped the sensor into :-(
