Results 1 to 8 of 8
Thread: Removal of swivel hub shims
    Expert Thirsty's Avatar
    Oct 2011
    Raceview, Ipswich QLD
    Who has done this? I have just done it and will never look back. Improved the feel through the steering wheel, Feels more stable on the road and most of all (no more steering wheel wobble). I have spent alot on the suspension to get a nice touring setup. This simple removal has improved the ride and handling the most.
    Troy
    1998 GU TI LS1
  2. The Following User Says Thank You to Thirsty For This Useful Post:
    growler2058 (18th March 2012)
    Feb 2011
    Shed
    45 Post(s)
    I will be giving that a shot for sure, ive got a bit of play there still after replacing these bearings
  5. #3
    Advanced maverick1's Avatar
    May 2011
    Nth QLD
    Has it affected the turning effort? Would it wreck the king pin bearings?
    Ford Mav 88 4.2 petrol.....stock standard.....
    Nothing is Impossible if you try
  6. #4
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    remove if necessary to recreate bearing preload would be my pick, I guess. More tension than required can't be good for the bearings?
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  7. #5
    Bald Hills, QLD
    As an act of desperation I have just removed my shims as steering wobble made car undeliverable.
    drivers side lower had no shim, but the other 3 did.
    Has anyone had any significant side-effects from removing the shims?
    How about if/ when wobble repo occurs? Replace swivel hub bearings?
  8. #6
    Advanced _RYAN_'s Avatar
    Oct 2013
    I've be running no shims for almost 2 years now. No issues at all.
  9. #7
    Patrol Guru sooty_10's Avatar
    May 2012
    Bendigo
    7 Post(s)
    I removed shims from my coil cab and ran it shimless for several years after I rebuilt all the front end bearings, never had an issue. Now with my wagon, similar thing, shims removed after a full font end rebuild and no issues yet.
  10. #8
    Expert @GUte's Avatar
    Aug 2013
    Beechworth, Nth East Vic
    Guys, you can't just remove shims and be done with it. Shims weren't fitted for no reason.
    After removal, did you check the preload on the swivel hub? What about premature axle seal wear due to axle misalignment?
    If you are going to remove shims, remove an equal amount top to bottom. If the preload is too great, purchase thinner shims from Nissan etc.
    If you think it has worked for you, it doesn't mean it's a correct cure for others to just remove shims randomly.
    For those running the offset bearings, you have a greater chance of splitting the cup with greater preload.
