Results 1 to 7 of 7
Thread: Purchasing a Patrol.
    Advanced Superoo's Avatar
    Fremantle. W.A.
    Hi, I'm new to this forum and also new to 4x4 driving. But I'm interested in buying a Patrol 06-10 turbo desiel 3.0 litre Auto is there some important pit falls that I should look out for?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hi mate welcome to the forum. Jump over to the introductions section and introduce yourself. People like to know who they're talking to
    As for the 06-10 3litre, Theres plenty of info around here to help your decision. You can use the search function in the top right corner of the screen.
    Welcome aboard
    Hello from Under Down Under!
    Feb 2011
    Shed
    45 Post(s)
    G'day mate welcome aboard gotta friendly mob here fulla great info and advice
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Check for the maitainance history ask the owner about previuos trips try avoid high beach work cars look for rust stone damage oil leaks the usual ask your mechanic to check it over if not great on the tools yourself and test drive for more than 5 mins to hear noises play in suspention etc drive at all speeds smooth and rough roads engage 4wd etc
    Such is the rule of honour.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Welcome aboard mate lots of info on zd30,s
    take your time read the threads then decide
    good luck with your choice
    Sydney
    Hi superroo
    Mate i have a 2003 GU111 3.0L Auto
    Thought i did enough resurch in relation the patrols 4wd abilaty and just asumed they were a tough as nails engine.
    Its well noted on this site that the early ZD30 engines had some major problems.
    From what i can work the GU111 and on were less likely to have engine failure if you have it serviced every 5,000km. That's oil , oil filter,fuel filter & air filter. Do these my self to keep the cost down.
    What i can tell you is bougth mine second hand with 127,000km on the clock of a dealer as a one owner and serviced every 5,000km as per the service history in the log book.
    I cant help but think that the previous owner was aware of the ZD30 engine failures.
    That being said i and happy with my choice and the way the patrol performs (chip & exhaust up grade) I plan on doing the NADS (you can also surch this) not sure if it is required for the later models.
    Good luck with the resurch
  8. #7
    North brissy
    Most of the zd issues were solved post 03 i believe however there are failsafes you can put it (NADS) which can help you prevent damage happening. Bad fuel seems to be the biggest killer of the 3L diesels with there high tolerance pumps etc. Nothing a well setup fuel filtration system cant sort out though
