Results 1 to 6 of 6
Thread: Why is my Ignition light staying on?
    This has been bugging me for a while and I have no idea what is going on?
    When I start the car up in the morning the ignition light goes off like it should do.
    As soon as I put my foot on the accelerator the light comes back on.
    I'm guessing the alternator's got issues but I can't really see anything wrong.
    Mind you i haven't looked properly at it but from a quick look it all seems fine?
    Does anyone know why this would be happening?
    Thanks!
    Melbourne East
    I don't know much about alternators myself.. all I know is there isn't much to look at on the outside. Anything electrical, always check your earth connection relative to the problem. Doesn't sound like a fuse problem or a dashboard fault. It may be lighting up on acceleration because it IS faulty.. but I always thought things like that flashed on and stayed on. I guess it means your battery won't be getting charged so you need to look at this pronto or else she won't start soon.
    I think there is just bushes and a coil inside the alternator. Might be worth testing to see if it's getting power to it when you accelerate in neutral. Maybe it's faulting because it isn't getting power? That would point to earth or some kind of connection problem in my mind.
    Could have lost 1 diode of 1 phase...
    Start her up... let her idle... put a Voltmeter on the battery... should read at least 13.5 volts, 13.8 even better 14 or just over, kickin butt
    Rev her up till the ign light comes on... recheck the voltage across the battery should be slightly higher than what you first got at idle.
    Anything below 13 or above 15 and your diode pack or reg is knackered or you have a dodgy wiring issue... there are a coupla other things it could be but only like 1 in a hundred... check the voltages first
    Finly Owner (11th September 2010)
    581 Post(s)
    ET - your on fire! (insert some kind of smiley face thats on fire)
    Sorry for the late reply and thanks for the suggestions.
    ET, you were right, it was the diode.
    Saved me a lot of heartache, thanks!
    Quote Originally Posted by GQ10 View Post
    Wow... finally got 1 right, now to work on the 9 I keep getting wrong
    Good on ya for posting back confirming what the fault was as well. A lot of times people post up a fault and get heaps of suggestions (which might or might not fix) but don't post it up what fixed it in the end which never helps anyone doing a search.
