18th March 2012, 09:57 AM
#21
Nup, not revving the engine at all Bob, are you talking about putting yours in neutral in the transfer case, not the gearbox ?? On the visor of my car it clearly states that you should not hesitate between high and low 4 wheel drive. As soon as i stopped doing this, there was no more problem, not a sound, just smooth transition. My post was more to do with wondering if i had originaly damaged anything ?? Maybe auto boxes and manual boxes operate differently with the transfer case ?
18th March 2012 09:57 AM
#22
1peter
The car is an auto, the gearbox was in neutral and was stationary with the engine running. As i originaly posted the problem was that i hesitated in neutral (between low 4x and high 4x) with the transfer case.
I have found with my GQ TB42 auto, when i put it into 4low i have to hold it there while i move the transmission to drive (or reverse)with the other hand.
Hello from Under Down Under!
18th March 2012, 09:59 AM
#23
taslucas
I have ground mine a few times while learning to do this! All good though. Thats why we love patrols......they are tuff!
18th March 2012, 10:02 AM
#24
1peter
Yes I was talking about the Transfer Case.
Just checked the instructions on my Visor and it says nothing about hesitating between high and low on the transfer Case.
Must be different with an auto transmission
18th March 2012, 10:07 AM
#25
Bob
just checked my visor....Yep it says to change the transfer between 4H and 4L in one movement and not to pause in N as this causes gear clashes. I have '91 TB42 Auto so it must be an auto thing
18th March 2012, 10:20 AM
#26
Hi Peter,
I don't think you would of done any damage.
Just checking......did you use the correct type/grade oil when you did your oil change?.
Cheers Rodney
18th March 2012, 10:38 AM
#27
Hardcore
no point in having teeth if you don't clean them once and awhile haha
Such is the rule of honour.
18th March 2012, 12:35 PM
#28
Banned
1peter
Thanks, i did not shift on the fly, it was all stationary, but sounded bad. lol.
Personally, if you were stationary I'd be very surprised if you even gave it a hurry up (they're tough boxes), but as said, just for peace of mind if you want to drop the transfer case fluid just to be sure of no filings, then do that mate - at least puts your mind at ease, but as said, would highly doubt you've done any real damage as such.
18th March 2012, 05:20 PM
#29
Thanks Bigrig, like i said everthing is changing smoothly now so hopefully all is ok.
18th March 2012, 09:24 PM
#30
RIP - valued member and true gentleman of this forum that will be missed by many!
Hi 1Peter,
Do you remember if your tfr case drain plug is magnetic? Most are.
If your is magnetic, evidence of your handiwork will stick there, and not float around further in the tfr case causing trouble
"As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
