Results 1 to 4 of 4
Thread: help!!! welsh plugs on 3lt diesel motor
    I have a 2003 3lt turbo diesel which is slow-leaking coolant.
    My local Nissan dealer reckoned it needed a thermostat housing kit but when he had a closer look after removing the alternator, found it was leaking from the front end of the motor.
    Can anyone confirm if that motor has a welsh plug located near the crankshaft?????
    I hope its as simple as that.
    Also, if anyone has had a similar problem can you give me a rough idea as to how mch $$$ I can expect to shell out?????
    Thanks guys,
    Mike
    Its not coming out of the tell tale of the waterpump is it? Could be as simple as that. Usually welsh plugs will run down the sides of the block if they have any.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    growler2058 (1st April 2012)
    Expert grimace's Avatar
    Apr 2011
    central coast N.S.W
    i don't want to be the bearer of bad news and i hope that it isn't for you sake but my brother in-law put his 1998 gu in the shop for that same reason and it turned out to be a cracked head once again i hope it isn't, cheers....
    2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
    Mar 2011
    NSW / NT / WA
    2003 shouldnt have the water cooled turbo, but there is a sender at top of the engine at the front. Also drivers side down low is the oil cooler. Couple of places to try.
  7. The Following User Says Thank You to outbackjack For This Useful Post:
    big daddy (3rd April 2012)
