15th January 2011, 02:10 PM
Rotaredom
Nissan Fast Installation
These instructions should hopefully get the Nissan Fast System up and running for you.
There are a few steps to installing Nissan Fast, I will do my best to explain, sorry if i get you completely lost, but that's what i get paid 2 do
Step 1 - Program Installation
1. In Windows Explorer or My Computer locate the AR.zip file you downloaded and extract the file to a Temp location. For this example i will use:C:\Temp\
2. After the file has been extracted locate this directory C:\TEMP\AR\FASTPRG\WIN2000\SETUP
3. Execute the Setup.EXE file
4. You will be prompted to choose a destination folder I will leave this as the default C:\Nissan
Select Next
5. You will then be prompted to Start Installation Select Next
6. It will then install, when the Install completes it will come back a prompt “Installation Complete” Select Finish
Step 2 - Check That The Installation Worked
1. There will now be a short cut placed some where on the windows task-bar, called Nissan Menu
2. Select the short cut Nissan Menu This will open the Nissan Fast Menu
Attachment 1706
3. Select any of the icons in the menu, it should come up with an Error Message
Attachment 1707
4. Select OK
5. Select Quit
Step 3 – Copy the Nissan Fast Catalogs
1. In Windows Explorer or My Computer locate the C:\TEMP\AR directory.
2. Copy the AR Folder to C:\NISSAN
Step 4 – Setting The CD ROM Setup
1. In Windows Explorer or My Computer locate the C:\Nissan directory
2. Locate the file NFSET.EXE and Execute
This will bring up the FastSet Nissan Fast for Windows NFSET menu
Attachment 1708
3. Select the CD-ROM SETUP TAB
4. Make sure Drive 1 is highlighted and select Browse, this will open the Browse For Folder window
5. Locate the C:\Nissan \AR folder and single left mouse click on it
6. Select OK
Drive1 should now look like this
Attachment 1711
4. Select OK
Step 5 - Run Nissan Fast
1. Select the short cut Nissan Menu on the Windows Task Bar
2. If it asks you to run a file called NFUdate.exe select YES , it will then go through an install procedure before opening the Nissan Fast Menu
3. Select the Fast System Icon
This will open the Main Nissan Fast Window
If you have AR 1 showing then you have the Australian Catalog working, now you can sit back and have a few
Attachment 1712
*NOTE - Known Issues *
1. If you run the E-Fast System and get a tdbg6.ocx error - you will need to download this file into the C:\Nissan Directory
2. If running a 64bit operation system, you will have to run it in XP Compatibility mode for E-Fast to work or you will still get a tdbg6.ocx error
15th January 2011 02:10 PM
15th March 2012, 06:23 PM
Rotaredom
Toddies Testing Thread 1
Merging post from one thread 2 another
Merging this post into Testing Thread 1
15th March 2012, 06:28 PM
POWER TRIP!!!!!! Hahahaha
tappa slappn about
Hello from Under Down Under!
16th March 2012, 12:53 AM
Nasty Dog - Moderator
Go for it Todd mate, great idea.
