Results 31 to 35 of 35
Thread: ADVICE sought PLS... YEP!! ZD30 2003 Nissan Patrol
  1. #31
    Beginner MadDan's Avatar
    Feb 2013
    how'd you go with your fuel issues?.. i'm currently having some drama's where my injector pump wont draw it's own fuel up from the tank.. and it's been suggested that it may be the front seal sucking air in on the pump?.. were you still getting fuel in your oil with your lift pump not running?
    Beginner Superjuice2072's Avatar
    Sunshine Coast, Queensland
    Hi MadDan,
    Yeah, I think they are fixed... most of the time!? Occasionally, the warning light comes ON, yet nothing is at fault from what I can work out. I haven't had the pump OFF, so haven't ruled out that the pump could have or still is sucking air through a front seal... that, I know very little about other than suggestions from members and yourself... I'm not getting fuel in the oil though, as the oil level is constant now, compared with previously. Has anyone made suggestions to you about your vehicle and how to rectify?
  4. #33
    Hi Team,
    4 years on from the last post in 2013, and the vehicle is still running very well. No limp or boost problems. Filter changes are easy with the lift pump. No increase in oil levels. No warning lights. Fuel tanks not leaking. Fuel lines not leaking. Original injectors. Due for new glow plugs. Haven't been in rough corrugation for years, but have pushed vehicle in some rough country without any problems. All going well. Cheers. Lindon
  5. #34
    464 Post(s)
    Quote Originally Posted by Superjuice2072 View Post
    Hi Team,
    Hi Lindon. Great to see you still have the might Patrol and its still going. I got a bit lost in reading through this thread. Lol. What was the final culprit?
  6. #35
    Even a few new earth straps wouldnt hurt battery to motor motor to chassis battery to body.
    I think Tojo earth different sections of the 4X4 like bullbar ,engine bay, cab general body and then cargo area.
    Maybe someone up your way can drop in and nut it out over a few beers, make sure all vacuum lines are new and not
    perished, easy and cheap to replace IMO. Youll get it soon enough
