Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 87
Thread: Jump Starter Packs
    109 Post(s)
    hey mate, the cable is pretty thin, after it started marks motor they were slightly warm. all i know is it started the motor no dramas and for the amount of times it would do so i would not imagine the cables heating up slightly per use wouldnt be an issue as long as youre not starting car after car after car.
    Yep it certainly did an amazing job!
    @MB what size is that diesel pump of yours?
    STEER CLEAR OF THE UNIDEN UPP120. It came with all the bells and whistles, even a carry case and a small air compressor. My lead shorted out one of the variable outputs and blew the whole control circuit, and it won't even charge. I eventually got the case off and checked to see if there was a fuse, and found that there is NO CIRCUIT PROTECTION.
    Also if you do some quick calculations using the basic size of the unit and attached conductors, you might get an unpleasant surprise regarding the claimed output. Hmmm, 600 amps through an EC5 connector? Methinks not...
    Plasnart (26th April 2017)
  5. #23
    472 Post(s)
    Not exactly sure mate, the manual is in Russian and never really needed to fix anything yet. It is only a twin cylinder air cooled but very long stroke as you can tell by the height of the donk.
  7. #24
    194 Post(s)
    [QUOTE=Plasnart;724460]At the forum meetup last weekend at MB's place, MB had problems starting a his large diesel water pump to transfer water from one dam up to another. Jumper leads from his Navara to the pump hardly provided enough power to turn it over but then @rusty_nail brings out his tiny little Wuldmar 600A jump starter and it absolutely kicked it in the guts!! Very very impressive for such a small unit!!
    [IMG]http://i.ebayimg.com/images/i/162152049150
    I think the actual power source is a 30V battery, not a 12V unit, and believe the amperage rating is a factor related to the 30V - 12V conversion, so in reality the cables only have to transfer 250a at 30V, to achieve a so called 600a charge at 12V. The duty cycle of the cable comes into how efficient this would be, heat is part of that rating. In most cases you will get a battery top up to allow starting with far less than this, hence why the cables look tiny. I have just purchased the 800a unit and agree you wont get 800a down the cables, even after they are smoke tested!
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudnut (26th April 2017), Plasnart (26th April 2017)
  9. #25
    Here is the unit's guts. As you can see it has a 12.23 volt battery rated at 12000mAH (12ampAH), which is impressive, but more realistic.
    Don't get me wrong. These units are bloody fantastic, and could be a life saver, especially if your alternator packs up in the middle of
    Whoop Whoop.
  10. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (26th April 2017)
  11. #26
    109 Post(s)
    OK just received the Wuldmar 600A unit and hoping it's a quality unit. When Rusty used his at the recent forum meetup to start MB's russian water pump it certainly impressed.
    The carry case and build quality of the unit itself seems good however the instruction pamphlet has been written by the KING OF CHINGLISH so that doesn't fill me with confidence in the product!
    This is exactly what the instructions say:
    Special Precautions of The Auto EPS
    1. Please put the blue plug enough in the Auto EPS.
    2. Make sure that the number of indicator lights are not less than 3.
    3. If the Auto EPS can not start car, please stop to start car. Please check the clip of car's battery clamped firmly or not. And check the battery clip whether clamped firmly or not, And check there any. rust or dirt in the car? Start the car again after cleaned-up and checked.
    4. During starting. If the blue indicator off or can't work. Please charger for the Auto EPS. Then it will work.
    5. During starting. If the Auto EPS can't continue to start car after starting 3-5 times. Please stop to start car. Please check the other breakdowns.Otherwise it will make the fuse and Auto EPS broken.
    6. When the car starts, remove Auto EPS cable from Auto EPS and disconnect red and black clamps to the car battery terminals within 30 seconds.
    We do not take respensibility for loss caused by your operation against above usages. If you need the car to start technical support can call the dealer.
    I won't bother listing the answers to common problems in use of the product as I haven't had enough time to work my way through the Chinglish!!!
    So if you're reading this Mr Wuldmar, the instruction pamphlet does not make your unit appealing to a potential purchaser (and maybe this is why they're only sold online, not in stores). If I looked at this in the store I would not have bought it. But anyway it might just be a ripper thing so here's hoping!
  12. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    mudnut (7th July 2017), rusty_nail (9th July 2017)
  13. #27
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    That made perfect sense , not sure what your on about .
  14. The Following User Says Thank You to GQtdauto For This Useful Post:
    Plasnart (7th July 2017)
  15. #28
    Jul 2017
    Central Vic
    I purchased a Genius 2600 (26 amp) charger that works a treat. It also has a jump start function that will do 5 minutes at 30amps. If you wait 10 minutes, it will charge up again. This is the 240V version but they also have 'in vehicle' versions.
    So far I've resurrected at least one battery and recharged the Patrol battery twice while faultfinding a fuel problem.
  16. The Following User Says Thank You to redrat For This Useful Post:
    Plasnart (8th July 2017)
  17. #29
    472 Post(s)
    Tractors battery is dead again and parked nose in, grrrr, gonna have to find out why soon.
    Raced out and bought one of these little fellas.
    https://www.industec.com.au/collecti...werall-supreme
    $199 on special today only at Repco, here's hoping it'll crank the 100hp Perkins over soon.
  18. #30
    472 Post(s)
    Happy Days:-) Started a 4.4L diesel no sweat!
    EDIT: Was only at 80% charge outa the box too.
  19. The Following 2 Users Say Thank You to MB For This Useful Post:
    GQtdauto (7th October 2017), TPC (7th October 2017)
