10th March 2012, 03:13 AM
1989 MK differentials
Hi,
i have 1989 MK SD33T short version and my car differential is:
Front : i think C200
Rear:
My rear differential C200 too or H233 ? and what is the differential rates? 4.3 or 4.6 ?
I want to use, 35" AT tires at summer
I want to use, 37-38 Extreme MT (maybe bogger) at winter
what you need to use for this ? 4.8 or 5.1 ?
and
where can I get rings & pinions
Regards.
Kursad
10th March 2012 03:13 AM
10th March 2012, 11:12 AM
The MKs had from factory , depending what country your from ???, 4.33 diff ratio (aussie version)
The diff ratios from an MQ , aussie versions, can be 4.11 (P40 6 cyl) 4.6 usually SD33/L28
The diffs from a ute will bolt straight in , these come in a 4.88 ratio, usually in a H260 diff model , strong as an ox
There were other diff ratio options in the MQ/MK range but in the overseas versions,these unfortunately arent easily avaliable in australia
The Following User Says Thank You to MQ MAD For This Useful Post:
Finly Owner (10th March 2012)
10th March 2012, 08:55 PM
I am from Turkey but , I dont sure for my patrol which country from... because customs goods. came from outside the my country. (i think, overseas versions)
so now, my rear diff C200 or H233 or H260 ?
11th March 2012, 05:28 PM
Rear , seems H233
The H260 diffs are HUGE, the centres arent interchangable between H233 and H260
Dont forget IF you change the rear diff ratio youll have to match the front the same ratio
13th March 2012, 02:20 AM
MQ MAD
Rear , seems H233
Thanks mate ,i think rear H233 , front C200
16th March 2012, 09:32 PM
From the pictures, the front is a C200 and the rear a H233.
I will not put 35 or bigger tires on a C200 diff. Spider gears fracture and CV's break. Good luck.
GQ '94 Petrol LPG 2" lift, drawers, roof rack with tent - tourer
MQ '82 L28 Auto Petrol LPG - current restoration project
