4th March 2012, 10:58 PM
Hi
i had a 99 GU 2.8 and put a 4.2td in took a week to do and sold my 2.8 and box for $3000
recon box cost $2100 td42 recond with turbo up grade inc injectors + pump +exhaust manafold +turbo cost $7200 tail shaft cost $120 with ballance radator Alloy cost $1300 and extras around $1800
not to cheap but ill be keeping this 1 for a while now.
sins the 2012 patrols are crap nissan has lost the plot sad to say
The Following User Says Thank You to aaron For This Useful Post:
4th March 2012 10:58 PM
5th March 2012, 10:18 AM
Fity
Was that a 3.0l?
Yeah ZD30, I saw it advertised at a dealer with ~250,000km and thought it was a bargain so I went to have a look. When I got there the salesman said "this engine's only done 250,000km"....
I looked and saw the car had done 700,000km, I wasn't impressed but thought it was a good opportunity to see how it drove. It drove quite well, then I told the salesman where to go!
The Following User Says Thank You to BearGUST For This Useful Post:
5th March 2012, 05:06 PM
Thanks for the info aaron. Do you mind if i ask you a few questions about the conversion?
I just got a price for everything I would need for a factory TD42T upgrade and it was ~$9500. Not to bad I think.
BearGUST, I wonder how many 3.0l it takes to make 700k?
5th March 2012, 10:05 PM
that is a good price bud as long as you have a 4.2 gear box it not to hard... happy to answer any questions u have if i know the answer lol...
is that for a Reco 4.2 or second hand ????
8th March 2012, 11:32 AM
aaron
2nd hand out of a GU.
What did you do for the engine mounts? Does the tacho hook up?
11th March 2012, 08:49 AM
just get 4.2 mounts they bolt straight in mate. am not to shor about the tacho tho as yours was a 3.0l yes ? if it was a 2.8 it will hook up the same
11th March 2012, 09:35 AM
#17
Thanks. I am looking at buying a 3.0l at the moment. But nothing is definite yet.
12th March 2012, 01:25 PM
#18
aaron
Hi
aaron yeah I was thinking of swaping out my 2.8td as well, so if I may bother you too
did you use the 2.8 diffs & tailshafts ?
& a bloke down here said the engine mounts on the chassis are to be moved but from what I've seen the 2.8 & 4.2 chassis measure up the same
but the later 3.0 chassis is different, did you just use the 4.2 engine mounts & rear crossmember & dropped it straight in ?
Cheers & any help is excelent Help
TonyD Lismore NSW
Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
12th March 2012, 04:12 PM
#19
shor hammer to easy
mate the 4.2 will drop in no probs there just use 4.2 mounts the cross membe is the same as the 2.8's you just need a 4.2 box and mounts. now for the tail shaft you will need 1 from a 4.2 as well. i used my
2.8 diffs tho u will need to change the yok to fit the 4.2 tail shaft. now as for the 3.0l not to shor what the go is there??????
12th March 2012, 07:06 PM
#20
Thanks for the Quick reply aaron thats great info & now I know what to buy & look for
