Results 1 to 5 of 5
Thread: Valve Train adjustment and noise?.
    Hardcore
    central coast nsw
    Been reading up on this and wondering what is the problem as most 42's have a noisy valve train.
    Why do these engines have a noisy valve train?.
    where is the valve train wear accruing.
    what to look for?.
    what should be replaced.
    cam, lifters, p-rods, rocker/shaft or valve top grind ?.
    some one should be able to enlighten us all.
    Expert ripper's Avatar
    Leeton NSW
    Quote Originally Posted by Robo View Post
    what to look for?
    Not sure about a lot of that, but I know our rockers need regrinding.
    I thought they were OK until I had to get one done, and then I compared it to the others and realised they all need doing.
    EDIT:
    Had to grind one because of the problem discussed here
    TB42-Rocker-Assembly-help-needed.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  4. The Following User Says Thank You to ripper For This Useful Post:
    Robo (3rd March 2012)
    Sep 2011
    Abbotsford , BC Canada
    I am planning to pull mine and have the rockers reground this July when i am off work. The rockers have had divits in them since I bought the Safari off an importer. They were never properly adjusted in Japan. Now to adjust them you have to tighten them a little bit closer than spec.
  6. The Following User Says Thank You to canuck For This Useful Post:
    Robo (7th March 2012)
  7. #4
    Hardcore
    central coast nsw
    Quote Originally Posted by canuck View Post
    Let me know all of what happens, will you.
    Leeton NSW
    That's sort of what I saw with ours. They have a ridge across them with a flat patch on both sides of it.
    The reground one has a smooth curve across the face of it. I'm guessing that curve would mean the rocker is in contact with the valve end for a lot longer, and that the ridge on the others may make a clicking noise as they open the valves.
  9. The Following User Says Thank You to ripper For This Useful Post:
    Robo (8th March 2012)
