Results 31 to 39 of 39
Thread: No more GU IV genuine keyless entry. Installed a Dynamco Cyclops controller.
  1. #31
    Nov 2011
    Brisvegas Northside
    WHhy wouldnt it come with OEM remotes from new?
    Is it "fitted for/ but not with" a wireless system?... or keyed central locking at least?
    All research I did when trying to sort our car out....most people changed over to Aftermarket systems, because of the cost savings (compared to Mr Nissans extotionate pricing)
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
    Feb 2012
    Lakes Entrance
    Quote Originally Posted by pjhicks3 View Post
    IT might be a little off the subject - I have a GU 2008 DX, which doesn't come with remotes from factory, but as I understand it I can just buy one, and program it in, is this correct?
    I'd say you probably can't. Usually in the DX models there's just a switch in the drivers side door which activates the other doors actuators. So you need to add a kit with a controller, actuator for the drivers side door & remotes. There's a similar kit mentioned earlier in this thread.
    Dave
  4. #33
    Advanced ShaunM's Avatar
    Dec 2012
    Hastings, VIC
    Massive thanks to davejones! You took all the work out of this job. Just installed a Warlock alarm from JB Hifi in about 30mins and it's working great.
  5. #34
    Feb 2012
    Lakes Entrance
    G'day Shaun
    No problem!
    Dave
  6. #35
    Advanced rodneyb81's Avatar
    Brisbane
    Hi Shaun when you installed the warlock kit was it a kg800 ?
    I have tried wiring the unit up but does not appear to be activating the central locking what form did you wire for positive, negative or positive/negative. Thanks Rodney ImageUploadedByTapatalk1370262281.308761.jpgImageUploadedByTapatalk1370262303.806712.jpg
  7. #36
    Dec 2012
    Hastings, VIC
    Quote Originally Posted by rodneyb81 View Post
    From memory I think it was the positive/negative trigger connected to pin 2 & 8 as shown in davejones' pic attached.
  8. #37
    Jun 2013
    Hi I am new to the forum and trying to install a keyless module to my 2004 Patrol. Besides the wires mention in the thread, there are 6 or 7 more wires. Does any one know what they are for?
  9. #38
    Feb 2018
    Hi DaveJones.
    Would you know if it is possible to reset the receiver and remove any previously coded FOBs?
    I am only able to get one FOB to operate at a time. There should be 4 memory slots for 4 keys but when I code a new one in, it deletes the previous one.
    Cheers!
  10. #39
    Feb 2012
    Lakes Entrance
    Quote Originally Posted by neilo99 View Post
    Hi DaveJones.
    Cheers!
    No idea sorry. Not sure I'd bother. The price of their remotes was why I went this way in the first place.
    DJ
