Results 1 to 9 of 9
Thread: Coolant colour
    WA Wheatbelt
    23 Post(s)
    Coolant colour
    Hey all.
    Just need a bit of advice about the colour of coolant water.
    Less than 2 years ago, I had a radiator service and a full flush and fluid replacement.
    The new coolant they put in, I hope, was red and not rusty brown.
    In the mechanic's report it says there was 'evidence of old coolant'
    It hasn't had a mud bath or been anywhere exciting since the coolant was last replaced.
    Is red coolant less than 2 years old considered 'old'?
    I think I'll use the green stuff next time.
    Rossco
    22 Post(s)
    mate a coolant change is every 40,000. Most coolants are green, the coolant in my bike is blue, I think I have seen red coolant,
    96 GQ coil/Cab
    08 G6eT
    WA Wheatbelt
    23 Post(s)
    Thanks Ben.
    From memory, that would be about right then.
    Rossco
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    most of the newer coolants last up to 5 years. there are differnet types on coolants for different engines. the colour means some difference in chemical makeup. sorry i can't remember the difference. a trip to your local supercheap\autostore will sort it out for you though. I think the nissan desiel spec one is green. Most toyota take the red. This may also vary between brands. I am trying to find more info for this thread
    Red Coolant (Organic Additive Technology): http://www.nulon.com.au/products/Coo.../#.Tz96QbR62So
    Green Coolant (Hybrid Additive Technology): http://www.nulon.com.au/products/Coo.../#.Tz96jrR62So
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  6. The Following User Says Thank You to scotty83 For This Useful Post:
    DX grunt (19th February 2012)
    a member of the menagerie MC97GQ's Avatar
    Jun 2011
    Nimmitabel in the deep, deep south of NSW
    Not sure about the chemical make up, but I know Nulon make red(pinky red) and green coolant.
    When I did the full flush on my cooling system the local auto shop recommended the green for a diesel.
    Mark
    Sorry scotty83 should have read your post more thoroughly as you covered what I said.
    Last edited by MC97GQ; 19th February 2012 at 12:43 AM. Reason: Typed before I read the thread
    Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
  8. The Following User Says Thank You to MC97GQ For This Useful Post:
  9. #6
    Advanced aaron's Avatar
    Jul 2011
    rockhampton
    thort red was for alloy block and head --- why the green is for cast block with cast or alloy head ?
  10. #7
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by aaron View Post
    The coolant for the ecotech commondoors is green. They have alloy heads.
    They should have a little book hanging off the shelf where you buy the coolant, that has all the specs etc
    Hello from Under Down Under!
  11. #8
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Correct, i use the same green coolant in alloy headed engines.
    I always thought Red was long life coolant (up to 5 years) Green was standard life (up to 2 years) , but i guess its just colouring at the end of the day and means little, ive also seen green auto transmission fluid, and purple engine oil.
  12. #9
    Feb 2012
    West Gippsland
    Coolant test strips are available from Repco or Bursons, most compotent garages check coolant when doing a service.
    Steve.
