Results 11 to 20 of 27
Thread: Wiring new electric brake controller
    Sep 2011
    adelaide
    18 Post(s)
    Sorry guy`s didn`t finish with a brake away system you need to charge the battery on the trailer part of the system
    Sep 2011
    Mount Annan
    Wild98
    A few months ago I took possession of my first CT. It's a Central Coast Campertrailer (very pleased with it).
    Back to topic, I have installed a TEKONSHA P3 for my electric brakes. I found it easy to install, very user friendly and work great.
  4. The Following User Says Thank You to shakey55 For This Useful Post:
    wildgu6 (20th February 2013)
  5. #13
    Hardcore
    central coast nsw
    1700 + hits in 2 days.
    Shows how many of us need the forum.
    " AB " we need ya heaps.
    Thanks man.
    done it again! speed reading
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  6. #14
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Thanks man.
    You'll find its over 12 months but a great effort all the same. Great forum for info and fun!!
    ________________________
    ______ 2017 D-Max _______
  7. #15
    And please ,please don't use scotch locks, do the job properly M2cw
    as scotch locks will fail
  8. #16
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Thanks man.
    What the ? am i missing something here
    Please shed some light Kris ??
    M2cw ??? lost me TD, are they connectors / joiners ???
  9. #17
    Sep 2010
    Adelaide S.A
    Im a dumb a$$ when it comes to electrics.... So what you are saying Pearcey, i can use the break away system or alternative is Anderson plug ??? or do they go hand in hand ???
  10. #18
    ACT
    Quote Originally Posted by wild98 View Post
    What the ? am i missing something here - Robo thought this thread had 1700 hits in 2 days
    Please shed some light Kris ??- I clarified it has been 12 months since the original post
    M2cw ??? lost me TD, are they connectors / joiners ??? Medication??
  11. The Following User Says Thank You to Maxhead For This Useful Post:
  12. #19
    Sep 2011
    adelaide
    18 Post(s)
    G`day Pete
    If you have a brake away system fitted to the trailer it will have a battery fitted and it will need to be charged. This battery is only used for the brake system so you can charge it from the aux pin in the trailer plug. you then fit the Anderson plug to charge your trailer battery.
    You only need a brake away system if the trailer weights over 2 ton.
    Hope this helps. Also check out Brake safe on the net as they make the system
    Beers,Scotches , Clipsal and F1 Pearcey
  13. The Following User Says Thank You to pearcey For This Useful Post:
  14. #20
    ACT
    You will also (by law)need a battery monitor for the brake away system. Its just an audible and visible alarm system which monitors your battery voltage in the trailer.
    This only applies if your trailer is over 2 T
  15. The Following User Says Thank You to Maxhead For This Useful Post:
